Amount of credits REST API
5164
6
02-09-2016 04:20 AM
LucioBordonaro
Hi everyone,
I'm currently developing a simple web app which allows to calculate directions using the REST API provided by esri/arcgis.
I'm in the test phase and I'm using an arcgis developer account. I've sometimes run into the trouble of finishing credits or using an expired token.
For tokens there are a lot of methods being exposed and I'm able to use them to handle the problem. Instead I've seen no methods for credits.
Did I miss something or credits can only be queried accessing the Usage Summary web page?
Thanks in advance.
Regards,
LucioB
RebeccaStrauch__GISP
I'm assuming you are asking about credits used on ArcGIS Online ?? You may want to start by looking at some of the information here ArcGIS Online | Service Credits
If you are wondering how many credits you have left, login to you account. Go to the My Organization page, and # of credits will be listed in upper right.
And on that same page, if you go to
  you can get more information about how your credits are being used.
There are also other location like Admin Tools for ArcGIS Online & Portal​  that might come in handy
If you are not talking about ArcGIS online or Portal...my apologies.  I'm not sure what/how credits are used by the REST API in other uses.
LucioBordonaro
You got it right, I'm asking for a way to get the number of credits I have left on ARCGIS Online.
But using REST API. I already know that I can look at them through the Usage Summary page of my account.
I'm looking for something like Twitter REST API for usage limits (have a look here)
LucioB
Nothing I can probably help with further (and our network blocks your link).  Tagging ArcGIS REST API  which may be a more focused place for your question.
ZhanLi
Hi Lucio, LucioB
Have you solved this problem? I have the same problem. If you have solved it, could you please tell me your solution?
Thanks.
Regards,
Zhan Li
RandyBurton
The same question is in this thread: Is there an ArcGIS REST API endpoint to view credit balance?
Although the first response is not marked as correct, it worked for me.
nicogis
You can write similar code
        //by nicogis
        using HttpClient httpClient = new HttpClient();
	var serializeOptions = new JsonSerializerOptions
		PropertyNamingPolicy = JsonNamingPolicy.CamelCase
        //generate a token with privileges (only credits) in agol
        string token = "...";
        string domainAGOL = "mydomainAGOL.maps.arcgis.com";
        var responseCreditiTotali = await httpClient.GetAsync($"https://{domainAGOL}/sharing/rest/portals/self?f=pjson&token={token}");
        if (responseCreditiTotali.IsSuccessStatusCode)
		Credits agolCredits = JsonSerializer.Deserialize<Credits>(await responseCreditiTotali.Content.ReadAsStreamAsync(), serializeOptions);
		agolCredits.AvailableCredits.Dump("Total credits");
public record Credits
	public double AvailableCredits { get; set; }
