ArcGIS REST APIs & Services Ques.
133
15.2M
1.8K
| Open | Currently, the modified date returned from a group in ArcGIS Online, or ArcGIS Enterprise does not change if members ... by AndrewRudin1 Frequent Contributor 1 0 | 1 | 0 | |
| Open | "opacity" property should be added to both IntegratedMeshLayer and IntegratedMesh3DTilesLayer, to enable changing op... by MichaelLev Frequent Contributor 0 0 | 0 | 0 | |
| Open | When using Esri soveServiceArea service with a drive time larger than 60 minutes, the polygons generated are generali... by XuejinRuan Occasional Contributor 0 0 | 0 | 0 | |
| Open | In SliceAnalysis it is stated that "SceneView.analyses can contain multiple slice analyses, but only one of these ana... by MichaelLev Frequent Contributor 0 0 | 0 | 0 | |
| In Product Plan | For applications that use ESRI's ArcGIS Javascript API (like EXB and WAB),it is crucially important that layers of ty... by MichaelLev Frequent Contributor 1 2 | 1 | 2 | |
| Implemented | The documentation for "Assign layer IDs " instructs the administrator on how to set up static layer IDs:https://pro.a... by johnolulu Emerging Contributor 1 5 | 1 | 5 | |
| Open | This was an issue that took us a (very) long time to debug, related to this known limitation. This enhancement is a s... by NatalieScott_HVP Emerging Contributor 1 0 | 1 | 0 | |
| Open | When I follow the instructions in these links:https://enterprise.arcgis.com/en/server/latest/publish-services/windows... by AndrewMernagh1 Emerging Contributor 5 0 | 5 | 0 | |
| Open | Users accessing ArcGIS Server services through their browser (https://<host>/<context>/rest/services) can find the co... by DavidDodds2 Occasional Contributor 1 1 | 1 | 1 | |
| Open | We show out our public data via Feature Service's. We have add the data documentation into the Feature Service descri... by LiisiPark Regular Contributor 0 0 | 0 | 0 | |
| Open | Currently, when a feature service is published that has editing privileges (any combination of create, modify, delete... by Zagorki Emerging Contributor 1 1 | 1 | 1 | |
| Open | AGOL and Portal Administrators need to understand dependencies between items. The REST API provides an endpoint on e... by AndrewRudin1 Frequent Contributor 1 0 | 1 | 0 | |
| Open | I would like to union together adjacent polygons form a cadastral featureservice (like this one from the BLM) to crea... by KirkKuykendall1 Frequent Contributor 0 0 | 0 | 0 | |
| Open | Please provide documentation on the limits on the number of REST API calls that can be made for ArcGIS Online or ArcG... by AndrewRudin1 Frequent Contributor 0 0 | 0 | 0 | |
| Open | Please create some way to obtain the definition query applied to existing map/feature services that reference an ente... by AndrewRudin1 Frequent Contributor 4 0 | 4 | 0 |
Idea Submission Guidelines
