Geoprocessing task related to intersect of shapefile fails to execute . File restlog.txt contains Error:Configuration <toolName> . GPServer not found.
Can you verify if the GP Service has started successfully and if the REST cache has been cleared since the startup of the service? Also check if this GP Task can be executed via the Services Directory page. Thanks
Thanks for your suggestion, since after clearing rest cache I succeeded in getting esriJobSucceeded . But the resultant shapefile after intersection is empty (it contains all the resultant attributes after join but no values). My model executes successfully from ArcCatelog->model -> Run entire model option. Even the resultant shape file also contains relevant data after join. All my intermediate and output shapefiles are placed in Inetpub->wwwroot.
