Geoprocessing task fails to execute
1842
04-13-2010 02:25 AM
DeepikaSingh
Geoprocessing task related to intersect of shapefile fails to execute . File  restlog.txt contains
Error:Configuration <toolName> . GPServer not found.
RaviNarayanan
Can you verify if the GP Service has started successfully and if the REST cache has been cleared since the startup of the service? Also check if this GP Task can be executed via the Services Directory page.
Thanks
DeepikaSingh
Thanks for your suggestion, since after clearing rest cache I succeeded in getting esriJobSucceeded .
But the resultant shapefile after intersection is empty (it contains all the resultant attributes after join  but no values).
My model executes successfully from ArcCatelog->model -> Run entire model option. Even the resultant  shape file also contains relevant data after join. All my intermediate and output shapefiles are placed in Inetpub->wwwroot.
Ranga_Tolapi
Dear deepikapals,
  I am also facing the similar kind of problem, do u have any solution for this? Appreciated ur support on this....
Ranga
