List available GPUs with CUDA
1832
6
08-01-2023 12:57 PM
Status: Closed
ÁkosHalmai
In the Options on the general tab, there is check box, called "Use GPU with CUDA compute capabilities...". It would be nice to see the available GPUs to rule out driver and other issues. It would be even better to be able to select & deselect certain GPUs, to include or exclude from calculations. If there is no available GPU, a big yellow warning would be great too.
Best regards,
Ákos Halmai
6 Comments
FelixRohrbach
Thank you for sharing this idea! I will definitely pick this up with the team and see how we can improve this within ArcGIS Reality Studio.
Out of curiosity - did you already experience some issues when using your GPU while processing?
ÁkosHalmai
@FelixRohrbach Thank you! I'd be happy to participate in the Early Adopter too!
The GPU: I have a Tesla M10 (old one), which is seemingly 4 card on a non-virtualized native environment, on Window Server 2019. I saw some utilization fluctuating around  a few percent, but I newer saw a full hit on the (non-display-attached) cards, however, I didn't check it continuously. In other softwares (like AgiSoft) they are used correctley.
Is it possible to use more than one card in Reality Studio? In which step should I check the utilization?
Best regards,
Ákos Halmai
FelixRohrbach
After some discussion with the team I can share some additional details regarding GPU usage within ArcGIS Reality Studio:
  • GPU is used for both visualizing data within Reality Studio as well as for some processing steps in the workflow
  • Reality Studio will use the same GPU for visualization as defined for ArcGIS Pro
  • For processing tasks, Reality Studio will use the first GPU as provided by the hardware IF it is supported (I'm told that for windows this is regulated by the registry)
  • Processing will only use one GPU - any additional GPUs are ignored
FelixRohrbach
Follow up on this topic I wanted to share that with ArcGIS Reality Studio 2024.2, a notification was added if the GPU drivers are outdated. We have noticed that old drivers often cause the processing to fall back to CPU processing (which will be slower) and we hope that with this new warning, user will update their drivers before processing further.
DVargas
With the release 2025.2 this GPU checkbox is not there anymore.
The system will automatically detect if the GPU with the proper drivers is available and use it. If not, will use the CPU.
As Felix mentioned, if the GPU is there but the drivers out of date, a warning message pops up informing that to the user.
FelixRohrbach
Status changed to: Closed
