Record track shifted to left or right
1935
01-25-2022 04:51 AM
AdrianPatrulescu
hi
It is possible to record "shifted" track to left or right in QuickCapture
I mean to the right or left of the position of the GPS receiver.
i have seen the videos (pictures below) where the capturing of the  track was done to right and left at the same time at fixed distance from the location of the receiver  (https://www.youtube.com/watch?v=JOnMdbrmA6w)
Thank you
Adrian
Keep your field crews safe and the workflow moving. Esri has developed an application to facilitate data collection while crews are on the go. Designed to be easy to use, QuickCapture works online and offline, plus it doesn't require any in-depth training. Because it's integrated with ArcGIS ...
JohnathanHasthorpe
Hi Adrian, no this is not currently possible in the app.
Mandy_Li
Hi Adrian, can you share your workflow with [email protected]? Thanks!
JohnathanHasthorpe
See this related question: https://community.esri.com/t5/arcgis-quickcapture-questions/is-it-possible-to-offset-a-line-by-a-fix...
The example shown in the video was a mock up for demo purposes only. You can't capture offsetted lines on the fly.
AdrianPatrulescu
Hi Johnathan
Thank you for you response
I was hoping to find a solution that don't require post processing of the data
I will take into consideration your solution.
So the recording of the data (left and right of the GPS position) presented in the video that I was mentioned in the initial post is not possible?
Thank you
Adrian
JohnathanHasthorpe
AdrianPatrulescu
Hi Johnathan
thank you for your reply
