QuickCapture text truncated
886
04-01-2025 12:37 AM
MichelleThreadingham44
I'm having a recurring issue in my QuickCapture apps where my comment text field is being truncated, or not being recorded at all.
It's set as a Button User Input - Multiline Text
The error happens at random, sometimes the text gets recorded, and other times even if I have only written a short piece of text such as 'Michelle test', only the 'Michelle' comes through. I check the source table and it is truncated there too so it's not a display error.
Has anyone else had this issue?
JohnathanHasthorpe
@MichelleThreadingham44 - can you confirm that you are using an Android device?
We do have a known limitation that relates to predictive text, where you need press return on the keyboard to enter the last word.
Yes I am using Android. I'll try a few tests where I press return at the end. Thanks for the suggestion!
Marijn_Wuyts
@JohnathanHasthorpe same issue here when using an Android device.
Multiline text was selected for my 'comment' text field (256 characters) and text is randomly truncated
