QuickCapture input mask
1473
02-15-2021 02:13 PM
DEI
Hi. I'm trying set up a button user input to automatically include a prefix based on a category by applying an input mask. For example, a sign would start with "SI", hydrant with "HY", etc. I think I'm running in to trouble when using characters that are defined under the input masks help section here. Can anyone please offer a work around?
JamieLambert
Hi @DEI,
Try this for special characters:
\HY >a!aaaaaaaaaaaa for a space between text or \HY->a!aaaaaaaaaaaa to add a '-', etc.
And so on for each button. Not sure how many characters (a) you need, but \ will escape the special characters. This will also make the first character upper case (>a!).
When the text input pops up on button push, just start typing. You don't need to move the cursor to the end of the string.
Cheers,
Jamie.
JamieLambert
Hi @DEI,
Cheers,
Jamie.
DEI
Thank you Jamie!
That worked perfectly!
