Quick Capture Trimble R1 GNSS reciever won't connect
2558
01-05-2020 01:17 AM
LiorHershkovitz
I'm using Trimble R1 gnss reciever
(firmware ver. 5.43)
I'm using also the apps GNSS status and GNSS direct on both iOS and Android
Quick capture won't connect to the R1 (the gnss app shows accuracy though)
On both iOS and Android
Is there any solution?
Thanks
Lior
GNSS Status
JohnathanHasthorpe
Hi Lior
I have done some testing on iOS (after the firmware fix) and can confirm that you can have the QuickCapture and the Trimble GNSS Status app running at the same time, both displaying the same (Trimble) reported locations and accuracies. QuickCapture was connected to the R1 using Bluetooth, and the use of the phone's internal position source was not required.
For Android, the use of Mock locations and Location Extras is required. The GNSS Status app is still used for configuration and to connect to real-time resources. QuickCapture should be configured to use "Internal Location Service" after GNSS Status has been set as the Mock Location provider in Android Developer Settings.
Could you share the phone devices and operating systems you were using and we can see if we can replicate the issue our side?
Thanks
John
JohnathanHasthorpe
R1 firmware update for iOS released today:
The FW v5.44 updater can be found HERE
Full FW v5.44 release notes can be found HERE
This should allow QuickCapture to connect directly to the R1 receiver when using an iOS device.
JohnathanHasthorpe
Hi Lior
Thanks
John
