Missing Attributes Under Capture Fields
837
08-29-2025 07:37 AM
usace_sam_rd3
I have a database view (feature class + attributes pulled from non-spatial table) that is served through a data store in my Portal for ArcGIS.  The View Feature Service has editing enabled.  When I attempt to build out the default data values for the button, only one of the attribute fields (out of 16) are visible under my Capture fields section, and that particular field is not included in my default visualization for that layer.  Suggestions of what to check?
JohnathanHasthorpe
Hi @usace_sam_rd3
This behaviour is not expected, and I was unable to reproduce it on my side.
Could you please log a support case so we can investigate this issue further?
John
