Line Feature Accuracy
177
07-21-2025 12:21 PM
BT_RPI
I'm creating a QuickCapture for the use of collecting shoreline oiling data during an oil spill. Part of that is having a trackline that runs throughout the day (to replace having to use a Garmin and downloading .gpx data). So that is always running, while I have different categories of shoreline oiling in an exclusion group. It's cool, everything runs fine, except I don't understand some data accuracy issues I have.
For reference, at the moment "trackline" is just a domain value in my Oiling Character feature, so this is happening in the same feature.
What I'm seeing is that I don't have an accurate overlay (photos attached).
The black line is hte track, and the other colors are different oiling characters (No oil, Fresh Oil, Tarballs, etc) along with the diamonds being photos. You can see where I make turns, that the lines aren't coincident, which is very confusing since they are all in the same feature. At first I thought it was jsut the transition between oiling characteristics, but the yellow is all over the place and not matched at all with the trackline.
BT_RPI
Anyway, I think it has to do with once stopping one attribute and starting another, if I "run and gun" the location services aren't doing their thing until I submit all of the survey questions from the button user inputs. Easy enough to slow down for a second to input those before moving on.  Also I changed the background trackline to points and a separate feature. Walking is now okay, but I'll have to see how it works when on something like an airboat and trying to cover shoreline miles.
