Is there a way, using QuickCapture, to collect/add new attributes to existing features?
1227
08-05-2019 09:13 AM
MichaelMcBain
Ex: Hydrants are physically marked by colors based on the water pressure. We have hydrant features but want to add this attribute for the FD so they know before they arrive on scene.
IsmaelChivite
Esri Notable Contributor
Hi Michael McBain‌. You cannot directly update existing features with QuickCapture‌. However, you could run a post-process against observations made with QuickCapture to transfer your observations to existing features.
For example, you can first run a Spatial Join using your QuickCapture data and your hydrants. You will want to use the Closest option and set a conservative search radius. See more details about Spatial Join here. Spatial Join will create a new feature layer, which will be temporary. In this layer  your hydrants will be joined to the QuickCapture observations.
You can then run the Add Join tool to the original Hydrants layer using the output from the previous step. Make sure you join using the Hydrant IDs.
Once you have that, you can then run the calculate tool to transfer the QuickCapture attributes to  your Hydrants and then Remove the Join.
All the above could be run manually from ArcGIS Pro if you need to transfer attributes sporadically, but it could also be automated with a Python script to run it regularly.
Hope this helps.
IsmaelChivite
Hope this helps.
