Dynamic Choice Lists after each collection
2049
03-19-2024 06:05 AM
ChrisBerryman
Since the enhancement of using arcade within quick capture to pull the nearest feature came out, we have used it several times.  We have looked at the new dynamic choice list but that seems to only be for when the solution is first opened, not after each capture. In the electric industry when doing aerial patrols of the lines, typically there are multi lines or structures and if it was possible to populate a list based on the proximity to those features, we could accurately report defects via air and also select the correct line/structure if necessary after selecting a defect button to then associate it with the correct asset.
MarikaVertzonis
@ChrisBerryman is your device online whilst doing the aerial patrol? If so, you should be able to 'pull down' on the list to update it (if manual mode is chosen) or when you start typing in the user input (if automatic mode is chosen). If you are offline, then yes you are correct, the list can't be updated.
ChrisBerryman
yeah its online, but the dynamic choice list looks to only be useful before a collection.  Our workflow is select a button on the quick capture form, then if multiple lines are nearby, show a drop down to let the user select the line or structure.  Also, I havnt seen any way to filter the list by what is nearby as the list is also getting its info from say the lines feature or the structure feature.
JohnathanHasthorpe
This is an enhancement to apply dynamic choice lists to button user inputs too.
I'll add this to our backlog.
ChrisBerryman
Thanks @JohnathanHasthorpe.  hopefully this feature gets added soon!
