Hi Adam
We are currently working on support for custom urls and the functionality will be available in 1.2 (Early October).
Please sign up to the QuickCapture Early Adopter Community to get access to a working beta build (and guidance) by the end of this week.
Note that the url scheme does not allow you to update a specific field - so the example above will not work.
John
Hi Adam
John
Note that custom url supporting beta builds are now available on EAC.
Hello Johnathan Hasthorpe,
I was trying to follow the directions listed here, but am unable to use that functionality in chrome on an android 9 Galaxy s9+
Any suggestions?
note: the QR code and link from the QR code do work to open the app and the project
Hi Joel
Can you confirm whether you are just trying to launch QuickCapture for ArcGIS directly from the web map by clicking the hyperlink? We are aware of some issues with Chrome launching the URLs in Android, so you could try another browser (e.g Firefox). If this is not a browser issue, can you please share an example of the URL that you are using.
John
Hello Johnathan,
I do believe it is a browser issue and if you're aware of chrome issues I'm good with that.
Johnathan Hasthorpe is it possible to launch Survey123 after capturing a line in quickcapture?
Hi Huong
No this is not possible. Please share your use case and I'll get it added to the enhancement we have for this.
John
We want to collect a line feature and at the end of the collection launch survey123 to collect a form associated with the line, so we can have the two connected by passing the globalID parents to the other feature. Right now i had to switch to using Collector with Survey123, but at first I wanted to use quickcapture survey123. Thanks
We are trying to do this in our organization as well. After reporting issues on a right of way patrol, we want to launch a Survey123 form for compliance reporting purposes. We would also want the Project User Input to transfer over.
