DistanceGeodetic not working in QuickCapture
337
02-07-2025 04:10 PM
Moff
DistanceGeodetic isn't working in QuickCapture. Will trigger in the designer, but blank on actual capture. The Distance function does work, but is not what I need.
Unsure if it's related to the same issue listed here: https://community.esri.com/t5/arcgis-field-maps-questions/distancegeodetic-not-working-in-fieldmaps/...Figured I would throw it out there as an issue.
Also - the help resource for the function within the Arcade editor has a different capitalization format than the current function.
JohnathanHasthorpe
The following worked for me:
var facilities = FeatureSetByName($map, "Medical");
var point_fs = Intersects(facilities, Buffer($feature, 2000, "meters"));
var min_dist = 99999;
var nearest_medicalName = null;
var geo = Geometry($feature);
for (var point in point_fs) {
  var point_geo = Geometry(point);
  var dist = DistanceGeodetic(geo, point_geo, "meters");
  if (dist < min_dist) {
    min_dist = dist;
    nearest_medicalName = point.name;
return nearest_medicalName;
Note that following:
- DistanceGeodetic function only works between 2 points, not lines,
- The designer will run the expression on the first feature in the feature layer you are targetting.
Please share your expression if you need assistance in troubleshooting this.
Cheers
John
