Adding property information to QuickCapture
1673
05-11-2022 07:55 AM
StevenParkinson
I am putting together a form to record contamination of household bins in QuickCapture and want to be able to record the property address when reporting a contamination so that I can build up a history.
Does anyone know if this is possible?
The only way I can think of getting around it is by recreating the form in Survey123 and adding a locator question but I like the simple button pressing in QuickCapture.
Steven
JohnathanHasthorpe
Hi - please see the section: Example 1: Reverse Geocoding in https://community.esri.com/t5/arcgis-quickcapture-blog/data-enrichment-with-arcgis-quickcapture-and/...
You can use webhooks to achieve what you want.
JohnathanHasthorpe
StevenParkinson
Excellent, that's the solution I was after. Thank you!
Steven
BrandiN
Now that Integromat has gone away, does Make allow for the same integration with QuickCapture, (if yes) is the process the same?
