Will the Remove Empty Feature Layers tool be added to ArcPro
4764
07-01-2021 09:35 PM
by Anonymous User
Not applicable
When loading a dataset that contains many map layers, it can be time consuming to filter out empty layers in ArcPro. My current workaround is selecting the entire dataset and using the “List By Selection” to identify which layers contain data. It works, but is very tedious!
Thanks in advance
Danny
DanHopkins
Hi Danny,
You can remove empty layers in ArcGIS Pro by doing the following:
1. Add layers to a map.
2. In the Contents pane, click Filter and select Empty feature layer.
3. In the Contents pane, select one or more empty feature layers, right-click and select Remove from the context menu. The empty feature layers are removed.
Regards,
Dan
DanHopkins
Hi Danny,
Regards,
Dan
DaynedeGroot
I dont have that option, i dont see the option for empty
DanHopkins
Hi DaynedeGroot,
What version of ArcGIS Pro are you using?
Do you have a feature layer in your map?
What types of layers do you have in your map?
Regards,
Dan
by Anonymous User
Not applicable
Thanks @DanHopkins !
I can't believed I missed that, appreciate your help 🙂
