ArcGIS Pro - Production Mapping: Product Library and Graphic Table Element
1021
03-15-2023 07:08 AM
Status: Open
TomekLetmanski
Hi Everybody!
Does anyone know if there are plans to create the Product Library functionality in ArcGIS Pro? I mean the same functionality of central management of cartographic products (solutions, map series, sheets) as in Esri Production Mapping for Desktop (ArcMap).
And also..., the same functionality of the ArcMap tool  - graphic table element: https://desktop.arcgis.com/en/arcmap/latest/extensions/production-mapping/what-is-a-graphic-table-el...
Can I found it in ArcGIS Pro?
Tomek
1 Comment
DanHopkins
Hi Tomek,
Thank you for your post.
Product Library functionality previously referred to as 'Projects in the Enterprise' in previous ArcGIS Pro Roadmaps is now referred to as Portal Projects for ArcGIS Pro and is slated as Near-term. Please refer to the ArcGIS Pro Roadmap - February 2023 at the following link:
https://community.esri.com/t5/arcgis-pro-documents/arcgis-pro-roadmap-february-2023/ta-p/1261591
Regarding where to find Graphic Table Element functionality in ArcGIS Pro, please refer to on how to add and modify table frames at the following link:
https://pro.arcgis.com/en/pro-app/latest/help/layouts/add-and-modify-table-frames.htm
Please see a brief video tutorial on how to work with a table frame at the link below:
https://pro.arcgis.com/en/pro-app/latest/help/layouts/work-with-a-table-frame.htm
Regards,
Dan
