Why does CIMSqlQueryDataConnection.FromJson choke on queryFields?
1797
02-12-2021 07:04 AM
KirkKuykendall1
I was under the impression that I can always deserialize CIM objects using json copied from a .lyrx file.
Is this true?
I created an SQL Query Layer with the UI, then saved it to a .lyrx file (see attached).
I then created a new file, sqldataconn1.json (see attached), with this json copied from the lyrx file:
    "type" : "CIMSqlQueryDataConnection",
	"workspaceConnectionString" : "SERVER=localhost;INSTANCE=sde:...",
	"workspaceFactory" : "SDE",
	"dataset" : "db1.DBO.%mytest2",
	"datasetType" : "esriDTFeatureClass",
	"sqlQuery" : "select OBJECTID,SHAPE,GDB_GEOMATTR_DATA from db1.dbo.TEST2",
	"srid" : "3857",
	"spatialReference" : {
	"wkid" : 102100,
	"latestWkid" : 3857
	"oIDFields" : "OBJECTID",
	"geometryType" : "esriGeometryPolygon",
	"extent" : {
	"xmin" : -11607361.9631999992,
	"ymin" : 3260858.89570000023,
	"xmax" : -10527607.362,
	"ymax" : 3930306.748499997,
	  "wkid" : 102100,
	  "latestWkid" : 3857
	"queryFields" : [
	  "name" : "OBJECTID",
	  "type" : "esriFieldTypeInteger",
	  "alias" : "OBJECTID"
	  "name" : "SHAPE",
	  "type" : "esriFieldTypeGeometry",
	  "alias" : "SHAPE",
	  "geometryDef" : {
		"avgNumPoints" : 0,
		"hasM" : false,
		"hasZ" : false,
		  "wkid" : 102100,
		  "latestWkid" : 3857
	  "name" : "GDB_GEOMATTR_DATA",
	  "type" : "esriFieldTypeBlob",
	  "alias" : "GDB_GEOMATTR_DATA"
	"spatialStorageType" : 2
However I get an exception:
"Cannot cast Newtonsoft.Json.Linq.JArray to Newtonsoft.Json.Linq.JToken."
If I remove the queryFields element from the json, sqldataconn2.json (see attached), it runs without error.
Tags (3)
UmaHarano
Hi Kirk
I see the issue you are experiencing. Adding the queryFields array causes the exception. The workflow is successful if I remove the queryFields array (the SQL query is still successfully executed).  The table gets successfully added to the map. I couldn't see any impact in the table added to the map.
Please remove the queryFields array in your JSON. In the meantime, I will follow-up and see why queryFields inclusion is causing the crash.
Thanks for reporting this!
Uma
UmaHarano
How are you using the JSON strings to create the new layer?
It is best to use the LayerDocument to accomplish this . LayerDocument gives you the ability to work with an "in-memory" representation of the layer. You can configure it (data connection, SQL query, renderers, etc) and then add it to the map. You can use an existing LayerX file to create a layer document object, and then access its CIM Definition to configure it.
 QueuedTask.Run( () => {
        //Creates an in memory copy of the existing lyrx file
        ArcGIS.Desktop.Mapping.LayerDocument lyrDoc = new ArcGIS.Desktop.Mapping.LayerDocument(@"C:\pathtoLayerXFile\layer.lyrx");
        var cimLayerDoc = lyrDoc.GetCIMLayerDocument();
        //Configure any aspects of the layer you want here. Query definitions, etc.
        cimLayerDoc.LayerDefinitions[0].Name = "MyNewLayer";
        //Create the layer in the active map using the layer document.
        var layerParams = new LayerCreationParams(cimLayerDoc);
        LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map,
        LayerPosition.AddToTop);
Here is a ProSnippet that also addresses this:
Create layer from a lyrx file
KirkKuykendall1
Hi Uma -
Thanks for responding.  My question is mainly how CIM deserialization works. I am able to create a featurelayer from an lyrx file as you describe.
So far I have assumed that any json found in a file (aprx, lyrx, etc.) could be deserialized by the FromJson static method on the CIM class.
For this specific use case though, suppose I have a 3rd party (non-Esri) table with geometry columns, and want to dynamically create an SQL query layer.  Can I safely do that without writing out an lyrx file?
If so, how does the absence of the queryFields array impact the resulting layer?
Kirk
UmaHarano
Hi Kirk
Uma
