Where do methods (such as OnSelectionChange) for a combo box that is nested in a dockpane go?
2277
06-03-2019 10:14 AM
JohnPhillipsGeo
There is plenty of documentation on how to add combo boxes to a toolbar/group from the daml and how to add functionality in the corresponding .cs file.  However, I haven't been able to find any documentation on how to put a combobox in the .xaml file for a dockpane and reference methods.
The method I would like to reference is OnSelectionChange:
https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Combo-boxes#determine-when-a-selection-occurs
I have my combobox declared in the .xaml
<DockPanel Grid.Row="2" Grid.Column="1">
<ComboBox Name ="ProfileBox"
Width="Auto" Height="Auto" IsEditable="True" Background="{DynamicResource Esri_BackgroundPressedBrush}" ItemsSource="{Binding Profiles}"
Foreground="{DynamicResource Esri_TextMenuBrush}">
</ComboBox>
</DockPanel>
and I am able to add items to a list and pass them as the source:
foreach (var item in profileRead)
string name = Path.GetFileNameWithoutExtension(item);
_profiles.Add(name);
private ObservableCollection<string> _profiles = new ObservableCollection<string>();
public ObservableCollection<string> Profiles
set
SetProperty(ref _profiles, value, () => Profiles);
NotifyPropertyChanged(() => Profiles);
get { return _profiles; }
I was able to reference the selection from the xaml.cs file:
public partial class Dockpane1View : UserControl
public static ComboBox profileBoxRef = new ComboBox();
public Dockpane1View()
InitializeComponent();
profileBoxRef = ProfileBox;
However, I cannot figure out how to implement OnSelectionChange.
JP
GKmieliauskas
Hi John,
If you do not use MVVM then you could add event to your xaml file like this:
<ComboBox x:Name="cbLayer" Margin="10" Width="150" SelectionChanged="Layer_SelectionChanged">
In xaml.cs you need to add method for SelectionChanged:
private void Layer_SelectionChanged(object sender, SelectionChangedEventArgs e)
In MVVM you do not need OnSelectionChange. You need to create property for SelectedItem or SelectedValue in your model view file and make binding in xaml
<ComboBox ItemsSource="{Binding Layers}" SelectedItem="{Binding SelectedLayer}"/>
JohnPhillipsGeo
Gintautas,
That worked like a charm, thank you!!
JP
