Using WhereClause in your QueryDef to create a QueryTable
1250
01-18-2022 12:15 PM
tzz_12
Hi Everyone,
I am trying to use a list of keys, mukeys, to search for these mukey within the mukey field in the component table and create a query table, CompTable. I keep getting an error, field not found at the line, WhereClause within the QueryDef. How do I write the WhereClause  correctly using a the mukeys list? Here is my script below:
//there is more script above, but I just included the script section related to this question.
using (Row row = rowCursor.Current)
mukeyCount++;
var mukey = Convert.ToString(row["MUKEY"]);
mukeys.Add(mukey);
QueryDef queryDef = new QueryDef
Tables = "component",
WhereClause = "mukey= mukeys[mukeycount]",  //error occurs here
SubFields = "component.cokey,component.mukey,component.comppct_r"
QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
Name = "CompTable",
PrimaryKeys = geodatabase.GetSQLSyntax().QualifyColumnName("component", "cokey")
Table queryTable = geodatabase.OpenQueryTable(queryTableDescription);
Thanks everyone!
Aashis
by Esri Contributor
Because the WhereClause is looking for the field name as mukeys[mukeycount] that is not available. I  am guessing that  you are trying to find a  field name in mukeys[mukeycount] which can be fetched as:
WhereClause = $"mukey= {mukeys[mukeycount]}"
Wolf
by Esri Regular Contributor
@Aashis  is correct your 'where' clause is not properly constructed.  I think your intend was to construct a where clause using the 'in' clause, for example:
mukey in (100, 101, 205)
The 'in' clause allows you to specify a list of possible matches.  Depending on the datatype of mukey you might have to surround the 'in' clause items in single quotes.
Here is a sample that worked for me:
protected override void OnClick()
  var mukeys = new List<string>();
  mukeys.Add("Test 1");
  mukeys.Add("Test 3");
  var inClause = string.Join("','", mukeys.Select(i => i.Replace("'", "''")));
  _ = QueuedTask.Run(() =>
      Tables = "testlines",
      WhereClause = $@"description in ('{inClause}')",
      SubFields = "objectid,description"
    System.Diagnostics.Trace.WriteLine($@"Where: {queryDef.WhereClause}");
    var defaultGdb = new FileGeodatabaseConnectionPath(new Uri(CoreModule.CurrentProject.DefaultGeodatabasePath));
    using (Geodatabase geodatabase = new Geodatabase(defaultGdb))
        Name = "testlines",
        PrimaryKeys = geodatabase.GetSQLSyntax().QualifyColumnName("testlines", "objectid")
      using (var queryTable = geodatabase.OpenQueryTable(queryTableDescription))
        using (var cursor = queryTable.Search ())
          while (cursor.MoveNext())
            using (var row = cursor.Current)
              System.Diagnostics.Trace.WriteLine($@"Found: {row["objectid"]} {row["description"]}");
The diagnostic output of this snippet looks like this:
Where: description in ('Test 1','Test 3')
Found: 9 Test 1
Found: 11 Test 3
