ArcGIS Pro SDK Add-In C#: How to get /set the Home Folder Option Path
2518
01-23-2022 01:32 AM
JadedEarth
Is it possible to set programmatically the Home Folder Path of a project?  And then also get the path after setting it?
I can manually set it in Options settings.  But having problems trying to get the home folder path in my program.
I don't want to use the default C:\ drive since sometimes users have no access to it in our servers.
Appreciate any help.
CharlesMacleod
Note: if u wanted to change the default (default"s") for all projects u might find these snippets useful:
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Content#set-generaloptions-to-use-defaults
JadedEarth
Never mind.  Found out the solution:
var homeDir = Project.Current.HomeFolderPath;
var drive = Directory.GetDirectoryRoot(homeDir);
if (drive == "C")
    //Set the current directory.
    Project.Current.SetHomeFolderPath(working_folder);
else
   //Disable controls
    TboxWorkingDir.IsEnabled = false;
    BtnSetup.IsEnabled = false;
CharlesMacleod
JadedEarth
Thank you.  Solves my problem.
