Using the CreateXYEventLayer tool
251
06-30-2025 02:24 PM
LandonPrince
I'm trying to use the "CreateXYEventLayer" tool to create a point event layer from a .csv file. It works when I use the tool from within the project, but when I try to do it via the SDK (with the same .csv file), it fails. Is something wrong with my parameters or the way that I am executing the tool? P.S. I'm very new to the ArcGIS SDK. Thanks in advance! Here is the code:
public async Task CreatePointEventLayerFromCsv(string csvPath)
     var parameters = Geoprocessing.MakeValueArray(
                                  csvPath,
                                  "X",
                                  "Y",
                                  "NewEventLayer",
                                  SpatialReferenceBuilder.CreateSpatialReference(4326)
     var result = await QueuedTask.Run(() =>
          return Geoprocessing.ExecuteToolAsync("CreateXYEventLayer_management", parameters);
     if (result.IsFailed)
          MessageBox.Show("Failed to create point event layer from CSV");
     else
          MessageBox.Show("Success");
ChrisUnderwood
Hello @LandonPrince , please can you describe a bit more about what happens when it "fails". Perhaps post some screenshots or other details.
SumitMishra_016
Make sure your CSV is:
  • Accessible from ArcGIS Pro (e.g., absolute path).
  • Compliant with ArcGIS standards (e.g., no mixed datatypes in fields).
  • Ideally added to the map or project — sometimes tools resolve better when it’s registered.
    // Ensure the path is valid and the CSV is accessible
    if (!File.Exists(csvPath))
        MessageBox.Show("CSV file not found.");
        return;
        csvPath,                         // Input Table
        "X",                             // X Field
        "Y",                             // Y Field
        "xy_layer",                      // Layer Name (not a path)
        SpatialReferenceBuilder.CreateSpatialReference(4326) // WGS84
    // Run tool
    var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
    var result = await Geoprocessing.ExecuteToolAsync(
        parameters,
        environments,
        null,
        null,
        GPExecuteToolFlags.Default
        MessageBox.Show("Failed to create point event layer from CSV:\n" + result.ErrorMessages);
    else
