How to Access the Selected Table or Feature Class in the Catalog Pane Context Menu (ArcGIS Pro Add-in)?
1578
07-13-2025 04:48 PM
IhabHassan
This is for ArcGIS Pro add-in development using Csharp .NET.
What is the
public, supported way to access the selected or right-clicked table or feature class in the Catalog pane from a context menu button?
  • Is there a public API to retrieve the selected item(s) in the Catalog pane context menu handler?
  • Are there any best practices or workarounds for obtaining the path or reference to the right-clicked item?
  • Internal interfaces like ICatalogPane and IProjectWindow are not accessible—are there alternatives?
Any guidance or code samples would be appreciated. Thank you!
Regards
Ihab
Tags (3)
GKmieliauskas
You can access them from Catalog pane :
        protected override void OnClick()
            var catalog = Project.GetCatalogPane();
            var items = catalog.SelectedItems;
            var item = items.OfType<ProGPXItem>().FirstOrDefault();
            if (item == null)
                return;
            MessageBox.Show($"Selected Custom Item: {item.Name}");
Change items.OfType object type <T> to your needs or use without <T>
GKmieliauskas
            if (item == null)
                return;
IhabHassan
thanks @GKmieliauskas , that worked nicely
Regards
Ihab
