Using Layer.ConnectionStatus
6551
17
12-04-2020 06:54 AM
BrianBulla
Honored Contributor
I'm using the following code to determine which layers in my project might have a missing data source, so that my code doesn't crash later and I can present the user with a message to fix the problem.  But when I call Layer.ConnectionStatus I get a 'NullReference' exception.  Which I guess makes sense, since the layer is missing the data source.  Am I just not using the ConnectionStatus properly??
 foreach (Layer layer in map.GetLayersAsFlattenedList().OfType<FeatureLayer>())
                        if (layer.ConnectionStatus == ConnectionStatus.Broken)
                            ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("SOME KIND OF ERROR MESSSAGE");
Wolf
by Esri Regular Contributor
Hi Brian,
 That was a tricky issue to solve... as far as the loading sequence you can find information here: https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-Advanced-Topics#2-admin-well-known-folders  Looking at this document i think the network share (in the registry) will trump everything else.  Pro is using the following sequence: network path (registry) … user defined paths … and finally the default path for add-ins.  The version tag in the config daml is actually only used to prevent an add-in from being loaded and run on an older version of Pro.
As far as the 'down cast' from FeatureLayer to BasicFeatureLayer, the only impact here is that FeatureLayers (you are getting FeatureLayers from the layer list) has more functionality (via properties and methods) than  BasicFeatureLayer from which it is derived from.
Wolf
Hi Brian,
I tried your code with FileGeodatabase as a datasource and the code worked fine after changed the folder name for the file GDB and restarted Pro.  With what type of datasource were you seeing this issue?
BrianBulla
Honored Contributor
Hi Wolfgang,
I am also using a FileGeodatabase.
When I debug it gets past the first layer, which is "Connected", but on the second layer (the one with the missing data source), I get the exception below thrown.
With mine, I am editing the name of the FeatureClass, not changing the folder name the FGDB sits in.  Not sure if that would be the difference??
Wolf
What build of Pro are you using?  I just renamed just one of my feature classes, then I opened a project that had a map with a layer datasource still referencing the old name and it worked:
BrianBulla
Honored Contributor
I am using 2.6.3
Wolf
i tried it with 2.6.3 and it works fine.  In my test i open the project and after the map is loaded i check the layers and none of them are null (i assume that the layer object in your code is null), even the one with the broken link.  Are you processing the layer in some way before you run the 'broken' check ?
BrianBulla
Honored Contributor
Hi Wolf,
No, there is nowhere in my code where I am doing anything with the object.  I have been messing around, checking for the broken layer in different way, but I always get a NullReference error.
Since I also need to check for joined tablets, I am using the BasicFeatureLayer object which also uses .ConnectionStatus, but still the same problem.
Can you post your code you are using and I will try that??  Here is mine below, all running in a QueuedTask.  The error happens right at the start of the first If statement.
                        var currentLayer = map.FindLayers(layer.Name).FirstOrDefault() as BasicFeatureLayer;
                        if (currentLayer.ConnectionStatus == ConnectionStatus.Broken)
                        {    //THE ERROR HAPPENS HERE!!!!!
                            ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(currentLayer.Name.ToString() + " has a missing data source.  Please remove or fix this layer before continuing.", "Missing Data Source");
                            return;
                        if ((currentLayer.GetTable().IsJoinedTable() == true) && (currentLayer.SelectionCount > 0))
                            ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(currentLayer.Name.ToString() + " has a joined table.  Please remove any joins before continuing.", "Joined table detected");
                            joinExists = true;
In Debug mode it seems like the values are getting read properly, yet I still get the NullReference exception.
Wolf
Hi Brian,
 Below is my test code.  I am not running within QueuedTask.Run, but i will try that shortly.   Strangely enough i got the exception once as well, but i was not able to duplicate the error after that.  i am still investigating that issue.  The code snippet is taken from the OnClick of a button i added to my test add-in.
protected override void OnClick()
try
		var map = MapView.Active.Map;
				//var currentLayer = map.FindLayers(layer.Name).FirstOrDefault() as BasicFeatureLayer;
				var currentLayer = layer as BasicFeatureLayer;
				System.Diagnostics.Debug.WriteLine($@"Name: {currentLayer.Name} Type: {currentLayer.GetType()} Connect status: {currentLayer.ConnectionStatus}");
catch (Exception ex)
		MessageBox.Show($@"Exception: {ex}");
BrianBulla
Honored Contributor
Hi Wolf,
When using your code, on a button with only that code on it, it works as expected and I see the 'Broken' status in the debug window.
If I take your code and plug it into mine, which is also the click event of a button, I still get the NullReference error.  I'll paste all of my code below, but it must be something in my code that is the problem....I'm just not really sure what, or why.
There's a fair bit going on here, but I've tried to highlight (******) where the issues are.....just in the OnClick() portion as far as I can tell.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using ArcGIS.Core.CIM;
using ArcGIS.Core.Data;
using ArcGIS.Core.Geometry;
using ArcGIS.Desktop.Catalog;
using ArcGIS.Desktop.Core;
using ArcGIS.Desktop.Editing;
using ArcGIS.Desktop.Extensions;
using ArcGIS.Desktop.Framework;
using ArcGIS.Desktop.Framework.Contracts;
using ArcGIS.Desktop.Framework.Dialogs;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Mapping;
using System.Collections;
using System.Windows.Input;
namespace ArcPro_DSM_Settings
    internal class FacilityID_Button : Button
        FeatureLayer localMunicipalityLayer;
        string gridNumber, structureType;
        int sequenceNumber;
        string settlementArea, vlsFolder;
            Map map = MapView.Active.Map;
//******* where I have inserted your code
            return;
            int featureCount = 0;
            int rejectedCount = 0;
            Cursor theCursor = Cursors.Wait;
            try
                QueuedTask.Run(() =>
                    //Get each layer that needs to be part of the intersection as a FeatureLayer
                    FeatureLayer gridLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.LAND_Grid", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    localMunicipalityLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.LAND_LocalMunicipality", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    FeatureLayer administrativeAreaLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.LAND_AdministrativeArea", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    FeatureLayer communitiesLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.LAND_Communities", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    FeatureLayer depotAreaLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.LAND_DepotArea", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    FeatureLayer pressureZoneLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.WAT_PressureZone", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    FeatureLayer vlsLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name.Equals("GISWRKS1.WORKS.VLS_Points", StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
                    //Check to make sure they are all in the map
                    if (gridLayer == null || localMunicipalityLayer == null || administrativeAreaLayer == null || communitiesLayer == null || depotAreaLayer == null || pressureZoneLayer == null)
                        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Please add the LAND and Water Pressure Zone layers before proceeding.", "Missing Layers");
                        return;
                    //Create the MAIN edit operation...this will show up on the Undo Stack
                    var editOperation = new ArcGIS.Desktop.Editing.EditOperation();
                    editOperation.Name = "Create new Facility IDs";
                    editOperation.ProgressMessage = "Calculating FacilityID's...";
                    editOperation.ShowProgressor = true;
                    editOperation.CancelMessage = "Operation Cancelled";
                    editOperation.ErrorMessage = "Error Creating FacilityIDs";
                    editOperation.EditOperationType = ArcGIS.Desktop.Editing.EditOperationType.Long;
                    ArcGIS.Desktop.Editing.EditOperation chainedOp = null;
                    //create the Inspector Object
                    var inspector = new ArcGIS.Desktop.Editing.Attributes.Inspector();
                    //create a flag to track the 'main' operation
                    bool isMainOperation = true;
                    //Check for any Joins on layers with a selected feature
                    Boolean joinExists = false;
                    Boolean brokenExists = false;
//***** where my original code get the NullReference exception
                            brokenExists = true;
                            joinExists = true;
                    if (joinExists || brokenExists)
                        return;
                    //Go through each layer in the map
                        //Does current layer have FACILITYID field??
                        Boolean facID_field = false;
                        facID_field = currentLayer.GetFieldDescriptions().Any(f => f.Name == "FACILITYID");
                        #region FACILITYID using FieldDescription
                        //Boolean facID_field = false;
                        //List<FieldDescription> theFields = currentLayer.GetFieldDescriptions();
                        //foreach (var fieldName in theFields)
                        //    if (fieldName.Name.ToString() == "FACILITYID")
                        //        facID_field = true;
                        #endregion
                        //if the FACILITYID field exists AND there is a selection, then continue....otherwise, look at next layer
                        if (currentLayer.SelectionCount > 0 && facID_field == true)
                            var selection = currentLayer.GetSelection();
                            IReadOnlyList<long> selectedOIDs = selection.GetObjectIDs();  //save the selected OBJECTIDs to a list.
                            structureType = GetFeatureClassCode(currentLayer);
                            //Loop through each selected OBJECTID, and pass the DRAWING and FACILITYID fields to the OpenDrawing method.
                            foreach (var oid in selectedOIDs)
                                inspector.Clear();
                                inspector.Load(currentLayer, oid);
                                MapPoint intersectPoint = null;
                                if (inspector["FACILITYID"].ToString() == "")
                                    //if (inspector.GeometryAttribute.GeometryType == GeometryType.Polyline || inspector.GeometryAttribute.GeometryType == GeometryType.Polygon)    //for polyline
                                    //    var pointCollection = ((Multipart)inspector.Shape).Points;
                                    //    intersectPoint = pointCollection[0];
                                    //else
                                    //    intersectPoint = inspector.Shape as MapPoint;    //for point
                                    intersectPoint = GeometryEngine.Instance.Centroid(inspector.Shape);
                                    //Make some of the initial edits
                                    inspector["GRIDNO"] = GetIntersectingField(intersectPoint, "GRIDNO", gridLayer);
                                    inspector["LOCALMUNICIPALITY"] = GetIntersectingField(intersectPoint, "LOCALMUNICIPALITY", localMunicipalityLayer);
                                    inspector["SETTLEMENTAREA"] = GetIntersectingField(intersectPoint, "NAME", communitiesLayer);
                                    inspector["DEPOTAREA"] = GetIntersectingField(intersectPoint, "DEPOTAREA", depotAreaLayer);
                                    //Need to pass a FeatureCLass to the GetNextFaciltyID procedure
                                    FeatureLayer currFLayer = currentLayer as FeatureLayer;
                                    FeatureClass currFClass = currFLayer.GetFeatureClass();
                                    //This is where the sequence number will get incremented each time (in the GetNextFacilityID)
                                    inspector["FACILITYID"] = GetNextFacilityID(currFClass, gridNumber);
                                    inspector["SEQUENCENO"] = sequenceNumber;
                                    //make some more edits
                                    inspector["STRUCTURETYPE"] = structureType;
                                    if (Properties.Settings.Default.facIDContractNumberSetting == true)
                                        inspector["CONTRACTNO"] = GetIntersectingField(intersectPoint, "CONTRACTNO", administrativeAreaLayer);
                                    //Some more edits based on the current layer
                                    if ((currentLayer.Name == "GISWRKS1.WORKS.SAN_Eff_Watermain") || (currentLayer.Name == "GISWRKS1.WORKS.SAN_Eff_WaterService") || (currentLayer.Name == "GISWRKS1.WORKS.SAN_Eff_Fitting") || (currentLayer.Name == "GISWRKS1.WORKS.SAN_Eff_ControlValve") || (currentLayer.Name == "GISWRKS1.WORKS.SAN_Eff_Hydrant"))
                                        inspector["WATERTYPE"] = "NONPOT";
                                    if (currentLayer.Name == "GISWRKS1.WORKS.SAN_Eff_Hydrant")
                                        inspector["SUBTYPECD"] = 3;
                                    if (currentLayer.Name == "GISWRKS1.WORKS.WAT_ControlValve")
                                        inspector["PRESSUREZONE"] = GetIntersectingField(intersectPoint, "WPZ", pressureZoneLayer);
                                    #region Code for VLS Points
                                    if (currentLayer.Name == "GISWRKS1.WORKS.VLS_Points")
                                        //Need to get the layer as a FeatureClass to do stats
                                        FeatureClass vlsFC = vlsLayer.GetFeatureClass();
                                        FeatureClassDefinition fcd = vlsFC.GetDefinition();
                                        //Setup the the fields and Statistics Description
                                        Field fldVLS_NO_1 = fcd.GetFields().First(x => x.Name.Equals("VLS_NO_1"));
                                        StatisticsDescription vlsMaxDesc = new StatisticsDescription(fldVLS_NO_1, new List<StatisticsFunction>() { StatisticsFunction.Max });
                                        TableStatisticsDescription tsd = new TableStatisticsDescription(new List<StatisticsDescription>() { vlsMaxDesc });
                                        IReadOnlyList<TableStatisticsResult> vlsStatsResult = vlsFC.CalculateStatistics(tsd);
                                        //Get the stat you are looking for
                                        int vlsMax = (int)vlsStatsResult.First().StatisticsResults.First().Max + 1;
                                        //Edit fields in the VLS with the new #
                                        inspector["VLS_NO_1"] = vlsMax;
                                        inspector["VLS_NO"] = vlsMax.ToString();
                                        switch (inspector["SETTLEMENTAREA"].ToString())
                                            case "AJAX":
                                                settlementArea = "AJA";
                                                vlsFolder = "AJAX";
                                                break;
                                            case "BLACKSTOCK":
                                                settlementArea = "BKSTK";
                                                vlsFolder = "CLARINGTON";
                                                break;
                                            case "BEAVERTON":
                                                settlementArea = "BROBE";
                                                vlsFolder = "BROCK";
                                                break;
                                            case "CANNINGTON":
                                                settlementArea = "BROCA";
                                                break;
                                            case "SUNDERLAND":
                                                settlementArea = "BROSL";
                                                break;
                                            case "BOWMANVILLE":
                                                settlementArea = "CLB";
                                                break;
                                            case "COURTICE":
                                                settlementArea = "NEWCT";
                                                break;
                                            case "NEWCASTLE":
                                                settlementArea = "NEWNE";
                                                break;
                                            case "ORONO":
                                                settlementArea = "NEWOR";
                                                break;
                                            case "NEWTONVILLE":
                                                settlementArea = "NEWTON";
                                                break;
                                            case "OSHAWA":
                                                settlementArea = "OSH";
                                                vlsFolder = "OSHAWA";
                                                break;
                                            case "PICKERING":
                                                settlementArea = "PIC";
                                                vlsFolder = "PICKERING";
                                                break;
                                            case "SCUGOG":
                                                settlementArea = "SCU";
                                                vlsFolder = "SCUGOG";
                                                break;
                                            case "GREENBANK":
                                                settlementArea = "SCUGB";
                                                break;
                                            case "PORT PERRY":
                                                settlementArea = "SCUPP";
                                                break;
                                            case "UXBRIDGE":
                                                settlementArea = "UXB";
                                                vlsFolder = "UXBRIDGE";
                                                break;
                                            case "UXVILLE":
                                                break;
                                            case "WHITBY":
                                                settlementArea = "WHI";
                                                vlsFolder = "WHITBY";
                                                break;
                                            case "BROOKLIN":
                                                settlementArea = "WHIBR";
                                                break;
                                            case "SEATON":
                                                settlementArea = "PICSEA";
                                                break;
                                            default:
                                                settlementArea = "ERROR";
                                                break;
                                        inspector["FILENAME"] = settlementArea + vlsMax.ToString() + ".pdf";
                                        inspector["COMMENTS"] = @"G:\OPERATIO\Data Systems Management\Valve Location System\PDF\" + vlsFolder + @"\" + settlementArea + vlsMax.ToString() + ".pdf";
                                        inspector["DWGMXD"] = @"http://cctvweb/cctv/VLS/PDF/" + vlsFolder + @"\" + settlementArea + vlsMax.ToString() + ".pdf";
                                    #endregion
                                    if (isMainOperation)
                                        editOperation.Modify(inspector);
                                        bool result = editOperation.Execute();
                                        //change the flag so we use the ChainedOp next
                                        isMainOperation = false;
                                    else
                                        chainedOp = editOperation.CreateChainedOperation();
                                        //queue up a Modify
                                        chainedOp.Modify(inspector);
                                        chainedOp.Execute();
                                    //Increase the feature count for the final tally
                                    featureCount++;
                                else
                                    rejectedCount++;
                            }   //go to next selected feature in current layer
                        }  //end of if (currentLayer.SelectionCount > 0 && facID_field == true)
                    }   //Go to the next layer in the map
                    ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(featureCount.ToString() + " FacilityID's created.  " + rejectedCount + " features already had FacilityID's.", "Process Complete");
                });     //end of QueuedTask
                ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(ex.ToString());
            finally
        //This does a SpatialQuery using the current feature point and a layer to get the intersecting field value
        public string GetIntersectingField(MapPoint point, string fieldName, FeatureLayer sourceLayer)
            try
                SpatialQueryFilter spatialFilter = new SpatialQueryFilter();
                spatialFilter.FilterGeometry = point;
                spatialFilter.SpatialRelationship = SpatialRelationship.Intersects;
                spatialFilter.SubFields = fieldName;
                string fieldValue = "";
                int i = 0;
                RowCursor gridCursor = sourceLayer.Search(spatialFilter);
                Feature feature;
                while (gridCursor.MoveNext())
                    using (feature = (Feature)gridCursor.Current)
                        int fieldPosition = feature.FindField(fieldName);
                        fieldValue = feature[fieldPosition].ToString();
                        i++;
                //if CONTRACTNO and more than one intersecting boundary, then show a message box and populate field with nothing
                if ((fieldName == "CONTRACTNO") && (i > 1))
                    fieldValue = null;
                    ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("There is more than one intersecting Contract Boundary for ??.  Please enter this field in manually.", "Contract Number");
                //if fieldName = NAME and it is blank, then find the SettlementArea by looking at the LocalMunicipality layer
                if ((fieldName == "NAME") && (fieldValue == ""))
                    fieldValue = GetIntersectingField(point, "LOCALMUNICIPALITY", localMunicipalityLayer);
                //set the gridNumber so we can use it again when we create the FACILITYID
                if (fieldName == "GRIDNO")
                    gridNumber = fieldValue;
                return fieldValue;
                return null;
        //This will return the next FacilityID
        public string GetNextFacilityID(FeatureClass fClass, string gridNum)
            try
                QueryFilter queryFilter = new QueryFilter();
                queryFilter.WhereClause = "GRIDNO ='" + gridNum + "'";
                queryFilter.SubFields = "SEQUENCENO";
                //create an array to hold all of the SEQUENCENO;  give it's first member the value zero
                ArrayList idList = new ArrayList();
                idList.Add(int.Parse("0"));
                RowCursor rCursor = fClass.Search(queryFilter);
                Feature feature;
                while (rCursor.MoveNext())
                    using (feature = (Feature)rCursor.Current)
                        int sequencePosition = feature.FindField("SEQUENCENO");
                        idList.Add(Convert.ToInt32(feature[sequencePosition]));
                //sort the list so we can get the highest value of SEQUENCENO
                idList.Sort();
                //the next # we want is the current highest number + 1
                int number = (int)idList[idList.Count - 1] + 1;
                sequenceNumber = number;
                //convert it to a string so we can add the zero placeholders to the front of it....it needs to be 4 digits.
                string finalNum = number.ToString();
                switch (finalNum.Length)
                    case 1:
                        finalNum = "000" + finalNum;
                        break;
                    case 2:
                        finalNum = "00" + finalNum;
                        break;
                    case 3:
                        finalNum = "0" + finalNum;
                        break;
                //return the full facility id, with the STRUCTURETYPE, GRIDNO, and SEQUENCENO
                return structureType + "-" + gridNumber + "-" + finalNum;
                return null;
        //This will return the StructureTypeCode for a layer
        public string GetFeatureClassCode(Layer layer)
            switch (layer.Name)
                case "GISWRKS1.WORKS.SAN_Chamber":
                    return "SCH";
                case "GISWRKS1.WORKS.SAN_Fitting":
                    return "SFT";
                case "GISWRKS1.WORKS.SAN_Manhole":
                    return "MH";
                case "GISWRKS1.WORKS.SAN_ControlValve":
                    return "SCV";
                case "GISWRKS1.WORKS.SAN_ReliefValve":
                    return "SRV";
                case "GISWRKS1.WORKS.SAN_InletOutletStructure":
                    return "IO";
                case "GISWRKS1.WORKS.SAN_WWTFacility":
                    return "WTP";
                case "GISWRKS1.WORKS.SAN_WWTFeature":
                    return "WWTF";
                case "GISWRKS1.WORKS.SAN_PumpingStation":
                    return "SPS";
                case "GISWRKS1.WORKS.SAN_Cleanout":
                    return "SCO";
                case "GISWRKS1.WORKS.SAN_ServicePoint":
                    return "SPS"; //SAME AS SAN_PUMPINGSTATION
                case "GISWRKS1.WORKS.SAN_SystemMeter":
                    return "SMTR"; //MISSING CODE IN GISWRKS1.WORKS.STRUCTTYPECODE
                case "GISWRKS1.WORKS.ForceMain":
                    return "FM";
                case "GISWRKS1.WORKS.GravitySewer":
                    return "SL";
                case "GISWRKS1.WORKS.SAN_SewerService":
                    return "SSL";
                case "GISWRKS1.WORKS.VLS_Points":
                    return "VLS";
                case "GISWRKS1.WORKS.WAT_SystemMeter":
                    return "MTR";
                case "GISWRKS1.WORKS.WAT_ServicePoint":
                    return "SP";
                case "GISWRKS1.WORKS.WaterSupplyFacility":
                    return "WSP";
                case "GISWRKS1.WORKS.WAT_PumpingStation":
                    return "WPS";
                case "GISWRKS1.WORKS.WAT_TestStation":
                    return "TST";
                case "GISWRKS1.WORKS.WAT_ControlValve":
                    return "WCV";
                case "GISWRKS1.WORKS.WAT_ReliefValve":
                    return "WRV";
                case "GISWRKS1.WORKS.WAT_Hydrant":
                    return "HYD";
                case "GISWRKS1.WORKS.WAT_Fitting":
                    return "WFT";
                case "GISWRKS1.WORKS.WaterMain":
                    return "WM";
                case "GISWRKS1.WORKS.WaterService":
                    return "WSL";
                case "GISWRKS1.WORKS.WAT_StorageFacility":
                    return "WST";
                case "GISWRKS1.WORKS.WAT_Feature":
                    return "WF";
                case "GISWRKS1.WORKS.WAT_Drainpipe":
                    return "DRNP";
                case "GISWRKS1.WORKS.WAT_BulkFillingStation":
                    return "BFS";
                case "GISWRKS1.WORKS.ssCleanOut":
                    return "STCO";
                case "GISWRKS1.WORKS.ssLateralPoint":
                    return "LP";
                case "GISWRKS1.WORKS.ssSystemValve":
                    return "SV";
                case "GISWRKS1.WORKS.ssControlValve":
                    return "CV";
                case "GISWRKS1.WORKS.ssMeter":
                    return "ME";
                case "GISWRKS1.WORKS.ssPump":
                    return "PMP";
                case "GISWRKS1.WORKS.ssCatchBasin":
                    return "SCB";
                case "GISWRKS1.WORKS.ssFitting":
                    return "SSFT";
                case "GISWRKS1.WORKS.ssMaintenanceHole":
                    return "STMH";
                case "GISWRKS1.WORKS.ssInletOutlet":
                    return "SIO";
                case "GISWRKS1.WORKS.ssLateralLine":
                    return "SLL";
                case "GISWRKS1.WORKS.ssPressurizedMain":
                    return "SPM";
                case "GISWRKS1.WORKS.ssGravityMain":
                    return "STM";
                case "GISWRKS1.WORKS.Clearwell":
                    return "CW";
                case "GISWRKS1.WORKS.Pump":
                    return "PU";
                case "GISWRKS1.WORKS.ssStormNetworkStructure":
                    return "SNS";
                case "GISWRKS1.WORKS.ssStormService":
                    return "SSL";
                case "GISWRKS1.WORKS.SAN_Eff_ControlValve":
                    return "EFCV";
                case "GISWRKS1.WORKS.SAN_Eff_Fitting":
                    return "EFFT";
                case "GISWRKS1.WORKS.SAN_Eff_Hydrant":
                    return "EFHYD";
                case "GISWRKS1.WORKS.SAN_Eff_Watermain":
                    return "EFWM";
                case "GISWRKS1.WORKS.SAN_Eff_WaterService":
                    return "EFWSL";
                case "GISWRKS1.WORKS.TBM_Chamber":
                    return "TBM";
                case "GISWRKS1.WORKS.TBM_Chamber_poly":
                    return "TBM";
                default:
                    return null;
BrianBulla
Honored Contributor
