I am adding a FeatureLayer to the current map. The FL is backed by table in a SQL Server database. This is how I add the FL:
var connProps = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
Instance = "my remote instance",
Database = "dbname",
User = "****",
Password = "****",
AuthenticationMode = AuthenticationMode.DBMS,
var gdb = new Geodatabase(connProps);
CIMSqlQueryDataConnection connection = new CIMSqlQueryDataConnection()
WorkspaceConnectionString = gdb.GetConnectionString(),
GeometryType = esriGeometryType.esriGeometryPolygon,
OIDFields = "OBJECTID",
Srid = "32632",
SqlQuery = "select * from [dbname].[fb_gdb].[TRAININGAREA]",
Dataset = "TrainingAreas",
DatasetType = esriDatasetType.esriDTFeatureClass
var layerParams = new LayerCreationParams(connection )
Name = Constants.LayerTrainingAreasName
var layer = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
The layer contains polygons and I added a renderer with a pink outline. During panning/zooming the features are not drawn well - sometimes completely missing, sometimes a chunk of the outline is missing:
If I add the same layer via Pro's Catalog -> Databases -> Add connection, and then drag and drop the layer into the map, it behaves correctly.
Any ideas?
I have tried to add the connection to the Catalog via code to see if that helps but was unable to figure out how to do that
Project.Current.AddItem( how do I make an IProjectItem out of the GDB or the connection?? )
Thanks, I indeed managed to add the item to the Catalog. However, it gets more complicated.
The item that can be added to the Catalog has to exist on disk (ItemType = PathItem). For that we need to create a connection file and save it to the disk. There is no .NET interface to build the connection file so the creation of the connection has to go via Python: via Geoprocessing.ExecuteToolAsync("management.CreateDatabaseConnection", @params)
... and that brings us to yet another problem that I describe here: https://community.esri.com/t5/arcgis-pro-sdk-questions/management-createdatabaseconnection-takes-2/m...
For those interested in the code
internal static object[] GetSdeFileParams()
var out_folder_path = Project.Current.HomeFolderPath;
var out_name = SDEConnectionName;
var database_platform = "SQL_SERVER";
var instance = "XXX";
var account_authentication = "DATABASE_AUTH";
var username = "USERID";
var password = "YYY";
var save_user_pass = "SAVE_USERNAME";
var database = "ZZZ";
return new object[]
out_folder_path,
out_name,
database_platform,
instance,
account_authentication,
username,
password,
save_user_pass,
database
var p = GetSdeFileParams();
var va = Geoprocessing.MakeValueArray(p);
IGPResult result = await Geoprocessing.ExecuteToolAsync("management.CreateDatabaseConnection", va);
await QueuedTask.Run(() =>
var sdeFilePath = System.IO.Path.Combine(Project.Current.HomeFolderPath, SDEConnectionName);
var item = ItemFactory.Instance.Create(sdeFilePath);
var gdbitem = item as GDBProjectItem;
Project.Current.AddItem(gdbitem);
