SpatialQueryFilter not return results
506
10-20-2023 12:23 PM
JonathanDewalt
New Contributor III
I have a simple task:  Get all point features that are within the view extent of the current map.
The point feature layer and map view are both in the same projection and i have tried all possible spatial relationship options but the featurelayer search function always comes back empty.  using ArcGIS Pro 3.0.2
Any suggestions?
var spatialQueryFilter = new SpatialQueryFilter
SpatialRelationship = SpatialRelationship.EnvelopeIntersects ,
FilterGeometry = theMapView.Extent,
// Get the features
using (var cursor = featureLayer.Search(spatialQueryFilter))
while (cursor.MoveNext())
using (var feature = cursor.Current as Feature)
features.Add(feature);
Tags (1)
JonathanDewalt
New Contributor III
This works
var map_pt1 = new Coordinate2D(theMapView.Extent.XMax, theMapView.Extent.YMax);
var map_pt2 = new Coordinate2D(theMapView.Extent.XMin, theMapView.Extent.YMin);
//Convert to an envelope
var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, theMapView.Map.SpatialReference);
KenBuja
MVP Esteemed Contributor
The documentation for SpatialQeryFilter has an example that selects all features within the current map view. Does this return any values?
  var sz = MapView.Active.GetViewSize();
  var map_pt1 = MapView.Active.ClientToMap(new System.Windows.Point(0, sz.Height));
  var map_pt2 = MapView.Active.ClientToMap(new System.Windows.Point(sz.Width, 0));
  var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, MapView.Active.Map.SpatialReference);
  //Project if needed to the layer spatial ref
  SpatialReference sr = null;
  using (var fc = featSceneLayer.GetFeatureClass())
  using (var fdef = fc.GetDefinition())
    sr = fdef.GetSpatialReference();
  var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
  //Set up a query filter
  var sf = new SpatialQueryFilter()
    FilterGeometry = env,
    SpatialRelationship = SpatialRelationship.Intersects,
    SubFields = "*"
  //Select against the feature service
  var select = featSceneLayer.Select(sf);
  if (select.GetCount() > 0)
    //enumerate over the selected features
    using (var rc = select.Search())
      while (rc.MoveNext())
        using (var feature = rc.Current as Feature)
          var oid = feature.GetObjectID();
          //etc.
JonathanDewalt
New Contributor III
This works if my return is how many polygons are within the view extent, but if I pass in a point layer, I get zero.
KenBuja
Instead of using the Intersects SpatialRelationship, try Contains
JonathanDewalt
New Contributor III
Yes.  I have tried Contains but get the same result.
JonathanDewalt
New Contributor III
This works
