Sort table based on a given field
1890
05-24-2023 02:01 PM
KisakyeM
How can one programmatically sort a table on a given field? This functionality is achieved in Pro by the user right clicking on a given field and electing to sort descending or ascending on that field. Is this attainable using the pro sdk?
@UmaHarano @CharlesMacleod @Wolf
Tags (3)
Wolf
by Esri Regular Contributor
Starting with Release 3.1, you can use the TableView class as described here:  ProConcepts Map Exploration · Esri/arcgis-pro-sdk Wiki (github.com)
and specifically the SortAscending Method:  SortAscending Method (TableView)—ArcGIS Pro
The code would look like this:
var tv = TableView.Active;
if (tv == null)
  return;
// sort the active field descending
if (tv.CanSortDescending)
  tv.SortDescending();
// sort the active field ascending
if (tv.CanSortAscending)
  tv.SortAscending();
// peform a custom sort programmatically
if (tv.CanCustomSort)
  // sort fields
  var dict = new Dictionary<string, FieldSortInfo>();
  dict.Add("STATE_NAME", FieldSortInfo.Asc);
  dict.Add("CITY_NAME", FieldSortInfo.Desc);
  await tv.SortAsync(dict);
// perform a custom sort via the UI
  tv.CustomSort();
Wolf
if (tv == null)
  return;
  tv.SortAscending();
  // sort fields
  tv.CustomSort();
Wolf
You can also search for the videos from Dev Summit 2023 specifically the session:
"Intermediate Data Visualization Using Table Controls"
You can find the session resources here:  Tech Sessions · Esri/arcgis-pro-sdk Wiki (github.com)
