Sort(Data Management) in ArcGIS Pro SDK
1381
05-24-2023 06:59 PM
tzz_12
I am getting the hang of using Geoprocessing tools in ArcGIS Pro SDK. I am not sure how to use the sort tool in the data management toolbox, such as how to code the sort_fields for the script below to work.
var sort_fields = new List<Tuple<string, string>>
    Tuple.Create(AggregateField,"ASCENDING"),
    Tuple.Create("MUKEY","DESCENDING")
var para = Geoprocessing.MakeValueArray(intersectFC,intersectSortFC, sort_fields);
utility.GPRun("management.Sort", para);
public async void GPRun(string GPTool, IReadOnlyList<string> parameters)
var gp_result = await Geoprocessing.ExecuteToolAsync(GPTool, parameters);
if (gp_result.IsFailed)
MessageBox.Show("Error in running the Geoprocessing Tool: " + GPTool, "Geoprocessing Error");
Thanks for your help!
Tags (3)
GKmieliauskas
Geoprocessing.MakeValueArray doesn't know how to manage your sorting fields.
Try to change List<Tuple<string, string>> parameter to simple string:
var sort_fields = $"{AggregateField} ASCENDING; MUKEY DESCENDING";
GKmieliauskas
