Setting button initial state
1327
10-11-2018 12:05 PM
MichaelPanlasigui
In my add-in I'm using Delegate Commands to control button sensitivity, but it does not seem to affect the initial button state.  I am not specifying any condition in the DAML, but all buttons appear enabled at startup instead of just the one desired.  Here are the corresponding methods and properties.
internal static void OnConnectButtonClick()
   _connected = true;
internal static bool CanOnConnectButtonClick
   get {
      return !_connected;
internal static void OnDisconnectButtonClick()
   _connected = false;
internal static bool CanOnDisconnectButtonClick
   get {
      return _connected;
What am I missing here?  It seems the only way I'm able to achieve the desired effect is to create a configuration with custom conditions and set the condition/state in the OnApplicationReady() method.  Is there a way to accomplish this with just an add-in?
CharlesMacleod
unless you use a Condition, you must set Autoload=true in your Config.daml. Otherwise, your add-in is not loaded until your button is clicked.
MichaelPanlasigui
Thank you, Charles, for the quick reply.  I failed to mention it in the initial post, but I am setting autoLoad="true" in Config.daml.  This does not seem affect the behavior.
MichaelPanlasigui
Taking your instruction further, in addition to setting autoLoad="true" for the module, I also set loadOnClck="false" on each button.  That seems to do the trick.  Thanks!
