Setting any dimensioning options programmatically results in a GeodatabaseException.
2045
07-26-2023 12:45 AM
DirkTillmanns
when working with an FGDB everything works, when working against a FeatureService the following errors occur. Setting any dimensioning options programmatically results in a GeodatabaseException. Only the settings "*.None" are processed. All option types are affected (see below). The error occurs with Pro 2.9.6 and with 3.1.2.
This is the Esri code decompiled with DotPeek that is causing the error:
DirkTillmanns
The get options methods also lead to exceptions.
CraigWilliams
Dirk, we're unable to reproduce this locally. Edits of a feature service work without error for us. I'd recommend logging a support case for a full investigation of your case.
AsimAhmad1
I want to generate dimension features without construction tools. I have beginning, end, and dimension line points. Can you please guide me in creating dimension features?
