How do you create a list of the records using field definition?
1207
09-01-2023 04:13 PM
tzz_12
I wrote a method to create a list of a feature class' ID field, but it takes at least a minute to complete. I was wondering if it would possible to just to create a definition of the field and create a list from it? Please see the script I started to try to use the definition of the field to create the list and my original method.
 Table table = featLayer.GetTable();
            using (TableDefinition tabledef = table.GetDefinition())
                var fieldID = tabledef.GetFields().First(x => x.Name.Equals(fieldIDName));
                foreach (var fieldID in fieldIDs)
                    FieldIDList.Add(fieldID.Name);
 public List<string> GetFieldIDs(FeatureLayer CopyLyr, string AggregateField)
            var FieldIDs = new List<string>();
            using (var rowCursor = CopyLyr.Search())
                while (rowCursor.MoveNext())
                    using (Row row = rowCursor.Current)
                        string fieldID = Convert.ToString(row[AggregateField]);
                        FieldIDs.Add(fieldID);
            return FieldIDs;
remo053
So this happens automatically already. I guess the trouble you face is having the options in a different sheet. Just don't do it that way, keep all the options together, extra lines can be hidden via the group option on the right click pop up menu https://speedtest.vet/ .
If you need I can put together a model sheet with those methods
Wolf
by Esri Regular Contributor
How many fields and records do you have in your table?
