Set Number Format on a layer attribute table
1999
12-14-2023 07:59 PM
KarlBeal
I have a layer feature table with fields joined from a plugin datasource. How can I programmatically change the number format on a joined field?
GKmieliauskas
You need to set NumberFormat property in layer field description:
var fieldDescriptions = featureLayer.GetFieldDescriptions();
foreach (var fieldDescr in fieldDescriptions)
    if (!fieldDescr.IsVisible || fieldDescr.Name == shapeField) continue;
    if(fieldDescr.Type == FieldType.Integer)
        var custNumbFormat = new CIMCustomNumberFormat();
        custNumbFormat.FormatString = "###-##-####";
        fieldDescr.NumberFormat = custNumbFormat;
featureLayer.SetFieldDescriptions(fieldDescriptions);
GKmieliauskas
KarlBeal
The code shown below is after a join. I do not see a change to the formatting in the attribute table after this executes.
var layerDef = layer.GetDefinition() as CIMFeatureLayer;
JoinLibrary.UpdateJoinTable(layerDef, oldTableName, newTableName); // setup join here
layer.SetDefinition(layerDef);
// Attempt to update numeric format
var fieldDescriptions = layer.GetFieldDescriptions();
    if (fieldDescr.Type == ArcGIS.Core.Data.FieldType.Double)
        var custNumbFormat = new CIMNumericFormat();
        custNumbFormat.ZeroPad = true;
        custNumbFormat.RoundingValue = 6;
GKmieliauskas
You need to set back field descriptions after modifying using SetFieldDescriptions method.
KarlBeal
Apologies I missed that line in your original post. Works as expected now.
