Set attributes in featurelayer edittemplate
2483
6
03-01-2021 11:08 PM
PrashantKirpan
I've created feature layer from featureservice. I've almost 73 predefined edit templates and want to add couple of attributes to each template after layer is getting added on map.
I got all templates using below code but not sure how to get predefined attributes and set values.
  IEnumerable<FeatureLayer> featLayers = theMap.GetLayersAsFlattenedList().OfType<FeatureLayer>();
foreach (FeatureLayer item in featLayers)
   foreach (var template in MappingExtensions.GetTemplates(item))
      //Define attribute for each template.
Any help would be appreciated.
-Prashant
KirkKuykendall1
This works for me:
private async Task UpdateTemplates(FeatureLayer fLayer)
    // set the default value for the DisplayName field
    // to whatever the name of the template is
    await QueuedTask.Run(() =>
        var layerDef = fLayer.GetDefinition() as CIMFeatureLayer;
        var featTemplates = layerDef.FeatureTemplates?.ToList();
        if (featTemplates == null)
            featTemplates = new List<CIMEditingTemplate>();
        foreach (var t in featTemplates.OfType<CIMFeatureTemplate>())
            if (t.DefaultValues == null)
                t.DefaultValues = new Dictionary<string, object>();
            Debug.Print(t.Name);
            foreach (var kvp in t.DefaultValues)
                Debug.Print($"\t {kvp.Key} : {kvp.Value}");
            t.DefaultValues["DisplayName"] = t.Name;
        layerDef.FeatureTemplates = featTemplates.ToArray();
        fLayer.SetDefinition(layerDef);
KirkKuykendall1
Did you try template.GetDefinition() to and then loop through each key value pair in CIMFeatureTemplate.DefaultValues , edit the definition, then call template.SetDefinition?
PrashantKirpan
I'm able to assign values for CIMFeatureTemplate but when I call SetDefinition, values are resetting again and showing empty.
Here is my code:
   CIMFeatureTemplate featTemplate = (CIMFeatureTemplate)template.GetDefinition();
   featTemplate.DefaultValues["fieldname"] = "SomeValue"; //Values are updated
   template.SetDefinition(featTemplate); //template.Defaultvlaues are empty here
KirkKuykendall1
This works for me:
PrashantKirpan
Thank you KirkKuykendall1,
Perfectly working.. used t.Defaultvalues["FieldName"] = "SomeValue" to update attributes in collection.
Really appreciate your help,
Prashant
by Anonymous User
Not applicable
PrashantKirpan
Thank you SeanJones,
Really helpful resources to understand templates in depth.
-Prashant
