Self-Intersecting Detect and Fix using SimplifyAsFeature
2916
03-16-2021 09:04 AM
MKa
I have discovered that some of the polygons that users are bringing into my system and creating a new object from have self intersections.  I need to be able to first detect if a self intersection exists, and if it does then repair it automatically.
Is SimplifyAsFeature the best method to do this with for both detection and fixing?
protected Geometry FixSelfIntersections(Geometry inGeometry)
            //I want to see if it has self intersections FIRST??
            bool isSelfIntersecting  = NEED TO FIND FIRST??;
            //Fix if it has intersections
            if (isSelfIntersecting)
                    inGeometry = GeometryEngine.Instance.SimplifyAsFeature(inGeometry, true);
            return inGeometry;
NarelleChedzey
You can use the GeometryEngine.Instance.IsSimpleAsFeature method to determine whether the feature is "simple".  (ie does not have self-intersections).  If the feature is not simple then you would call GeometryEngine.Instance.SimplifyAsFeature to simplify it.
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/#topic15566.html
The Geometry Concepts page has a section describing these two methods
https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-Geometry#simplifyasfeature-and-issimpleasfea...
Narelle
NarelleChedzey
Narelle
