RowChangedEvent does not get captured when using Calculate.
747
09-11-2023 09:52 AM
KhamilleJaynes
Using ArcGIS Pro SDK version 3.1.0.41833.
I am trying to capture when a table is edited. I am able to capture any table edits done directly in the table (for example, when you double click in a cell and manually type out the new value). I am also able to capture when table edits are done programmatically using EditOperation callback.
However, when I select a value/values and edit using the Calculate button in the table, it isn't being caught by the RowChangedEvent handler. It is being caught by OnEditCompleting and OnEditCompleted, etc. However, I want the capture to be more specific.
Any advice how to specifically capture this event? Thank you.
