Return account string that not found in current layer?
769
06-16-2020 01:32 PM
helenchu
All,
I have the codes below to do selection but I also need the code to return to me what account in the 'queryString' that it could not find in my layer.  How do I do that?  Thank you!
queryString = accountNum in ('123', '456', '789')
public static Task<int> SelectByAttributeAsync(string featureLayerName, string queryString)
            return QueuedTask.Run(async () =>
                var firstLyr =
                    MapView.Active.Map.FindLayers(featureLayerName).FirstOrDefault() as FeatureLayer;
                if (firstLyr == null) throw new Exception(string.Format("The feature class: {0} does not exist", featureLayerName));
                var qf = new QueryFilter()
                    WhereClause = queryString,
                    SubFields = "*"
                MapView.Active.ZoomToSelected();
                MapView.Active.ZoomToSelected(new TimeSpan(0, 0, 3), true);
         return selectionCount;
Wolf
by Esri Regular Contributor
You can use the snippet below to get this result when searching for these accounts (type string) ' "Test 0", "Test 1", "Test x"' - Note that only Test x doesn't exist:
In essence you first do your selection and then search through the selected set one by one to find the 'missing' item.
 protected override async void OnClick()
      Tuple<int, string> selectionInfo = null;
      try
        var accounts = new List<string>() { "Test 0", "Test 1", "Test x" };
        selectionInfo = await SelectByAttributeAsync("TestPoints", accounts);
      catch (Exception ex)
        MessageBox.Show(ex.ToString());
      _ = MapView.Active.ZoomToSelectedAsync(new TimeSpan(0, 0, 3), true);
      MessageBox.Show($@"{selectionInfo.Item1} records were selected - {selectionInfo.Item2}");
    public static Task<Tuple<int, string>> SelectByAttributeAsync(string featureLayerName, List<string> accounts)
      return QueuedTask.Run(() =>
        var firstLyr = MapView.Active.Map.FindLayers(featureLayerName).FirstOrDefault() as FeatureLayer;
        // make list of accounts into 'in' clause
        var commaList = string.Join(",", accounts.Select(p => $@"'{p}'"));
          WhereClause = $@"description in ({commaList})",
          SubFields = "*"
        var selection = firstLyr.Select(qf);
        // remainingAccounts tracks first all accounts and each found account will be removed
        var remainingAccounts = new List<string>(accounts);
        using (var foundCursor = firstLyr.Search(new QueryFilter() { ObjectIDs = selection.GetObjectIDs() }))
          while (foundCursor.MoveNext())
            using (var row = foundCursor.Current)
              var foundAccount = row["description"].ToString();
              remainingAccounts.Remove(foundAccount);
        var msg = string.Empty;
        if (remainingAccounts.Count == 0) msg = "All records found";
        else msg = $@"Not found: {string.Join (",", remainingAccounts)}";
        return new Tuple<int, string> (selection.GetCount(), msg);
Wolf
      try
          SubFields = "*"
helenchu
I've successfully got it worked with my codes.  Thank you so very much.  You're truly life saver!
