Referencing an image in Splash Screen
2880
6
12-06-2021 09:44 AM
JohnnyHarley232
I am creating a custom splash screen with an image being referenced in the pane. Currently I have
<Image Source="Images/trekk.jpg" />
 Trekk.jpg is in the Images folder of the project. When I save and build the project.... and start debugging... The splash screen displays with all my changes except for the Image being shown.
Is there something further I need to do?
KirkKuykendall1
Did you try setting Grid.Background to an ImageBrush?
This works for me ...
JohnnyHarley232
Kirk,
Thanks for the response back. I dont want the logo to be a background since I already have a desired background in place. I have attached a screenshot of my current product in the designer and snippet of the relevant code.
KirkKuykendall1
What are your build action, and copy to output settings set to?
JohnnyHarley232
Kirk, Attached is the setting for that photo. Is there any other setting I need to look at when building the solution?
GKmieliauskas
Have you tried like this:
<Image Source="/your_config_name;component/Images/trekk.png"/>
KirkKuykendall1
The original question has
But the follow-up post has
Esri's default when creating a splash via New>Project .... Pro Managed Configuration results in a project with a UI and Images folders.
Notice how the Source path in the xaml in the UI folder has a relative path to the images in the Images folder:
So, if your xaml is in a (UI) folder that is a sibling to the Images folder, perhaps try using a ".." for the relative path in the Source.
