Programmatically select template from favorites
1899
01-30-2023 03:32 AM
FridjofSchmidt
Hello, I would like to programmatically select a feature editing template from the list of favorites. For example, when the user clicks a button, the list of favorite templates appears and the first item under a certain folder gets selected. Is there a recommended way of doing this?
GKmieliauskas
Have you tried GetTemplates method  from MappingExtensions?
More info here.
There is ArcGIS Pro SDK community sample for choosing template from list:
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Editing/TransferAttributes
FridjofSchmidt
OK, this might be an option, but actually I was planning to go with the existing UI: Selecting a template from the list of favorites so that it appears selected, expands, and activates its default tool.
It seems I can get hold of the TemplateFoldersVM in esri_editing_CreateFeaturesDockPane and its children via reflection, but I'd prefer a supported solution.
NarelleChedzey
Hello,
Currently there is no method in the API to access the set of favorite templates.  Access to templates is currently only from a map member (layer or standalone table) using the GetTemplates method.  I will add an issue to our backlog to address this in a future release.
Narelle
FridjofSchmidt
Thank you Narelle, I really appreciate it and I am looking forward to working with this future release.
For those interested, my current approach is this:
static bool SelectFirstTemplateFromFolder(string folderName)
	var pane = FrameworkApplication.DockPaneManager.Find(DAML.Dockpane.esri_editing_CreateFeaturesDockPane);
	pane.Activate();
	var paneType = pane.GetType();
	var pi = paneType.GetProperty("SubPanelIndex");
	pi?.SetValue(pane, 0);
	pi?.SetValue(pane, 1); // Switch to Favorites
	pi = paneType.GetProperty("TemplateFoldersVM");
	var templateFoldersVM = pi?.GetValue(pane);
	pi = templateFoldersVM?.GetType().GetProperty("RootFolderChildren");
	if (pi?.GetValue(templateFoldersVM) is IEnumerable col)
		foreach (var item in col)
			var itemType = item.GetType();
			pi = itemType.GetProperty("Name");
			var name = pi.GetValue(item);
			if (Equals(name, folderName))
				pi = itemType.GetProperty("Children");
				if (pi?.GetValue(item) is IEnumerable children)
					var enumerator = children.GetEnumerator();
					if (enumerator.MoveNext())
						var child = enumerator.Current;
						var childType = child.GetType();
						pi = childType.GetProperty("IsSelected");
						pi.SetValue(child, false);
						pi.SetValue(child, true);
						return true;
				break;
	return false;
