Problems with regression testing - missing dll
2058
06-21-2023 06:06 AM
TorbjørnDalløkken2
I've been working on a add-in, which works ok in Pro. I'm quite new to regression testing / unit testing, but I'd like to try it on this new add-in. I've followed the steps in the ProGuide Regression Testing, but I get an error when trying to run the tests. The error says:
Class Initialization method UnitTest.LayoutTest.ClassInitialize threw exception. System.AggregateException: System.AggregateException: One or more errors occurred. (Object reference not set to an instance of an object.) ---> System.NullReferenceException: Object reference not set to an instance of an object..
When trying to debug the test, I see that the error originates at the startApplication-method of the class TestEnvironment. The message says:
System.DllNotFoundException: 'Unable to load DLL 'DADFLib.dll' or one of its dependencies: The the specified module could not be found
Does anyone know what might be wrong here?
GKmieliauskas
TorbjørnDalløkken2
Yes, I've read that thread. My project compiles to x64 and since I'm using MSTest, just like the example from ESRI, there are no Host.Initialize().
