Possible to get GDB-level metadata?
1712
08-01-2023 01:02 PM
TimStone
I'm trying to read some of the geodatabase-level metadata from the GDB using the FGDB API.
I know how to do this for tables, using, for instance, Table.GetDefinition().
In particular, I'd like to get the "character set" the GDB is using.  I've attached a screen snap from ArcCatalog showing how I can see this in ArcCatalog in the screen snap, the GDB is using "utf8".
To get to this screen in ArcCatalog:
Click the GDB, then click the "Description" pane at the top, then the "Edit" pane at the top.
Then I click on "Details" under "Metadata".
Is it possible to get this info using the File GDB API?
thanks!
