On application close method
4109
10
09-19-2017 08:09 AM
DrewD
Hello, I was wondering if there was a way to close an add-in pane when Arcpro is shutdown. As you know Arcpro remembers which tabs/windows were open in the previous session, and I don't want the add-in tab to be available when the application is reopened.
Are there any simple overrides that I could implement?
Alternatively on open would be fine too, I've been trying this.close(); and FrameworkApplication.Panes.ClosePane(this.InstanceID); but can't get them to work
UmaHarano
Hi Drew
You can accomplish this by using the ProjectClosingEvent.  This is the code that worked for me -
 private static async Task OnProjectClosingAsync(CancelEventArgs arg)
            FrameworkApplication.Panes.ClosePane(MyPaneID);
            await Project.Current.SaveAsync();
Thanks
Uma
DrewD
Thanks Uma, I'm trying it but not having any luck. MyPaneID is a unsigned int, would I find it using this.InstanceID; ?
UmaHarano
i Drew
You could have multiple instances (InstanceIDs) of your pane. So you can iterate through the Panes to get "your" panes only and then close them like this:
            IList<uint> myPaneInstanceIDs = new List<uint>();
            foreach (Pane pane in FrameworkApplication.Panes)
                if (pane.ContentID == _viewPaneID) //this is the DAML id of your pane.
                    myPaneInstanceIDs.Add(pane.InstanceID); //InstanceID of your pane, could be multiple, so build the collection
            foreach (var instanceID in myPaneInstanceIDs) //close each of "your" panes.
                FrameworkApplication.Panes.ClosePane(instanceID);
            await Project.Current.SaveAsync(); //save the project.
DrewD
Thank you again Uma, for some reason the pane still doesn't close, could there be a level of protection preventing it from being closed? I've attached a msg box below:
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Closed pane " + instanceID);
and it pops up a dialog saying "closed pane 9" but nothing is actually changes
UmaHarano
Hi Drew
Can you please share the code where you get the instanceID of the pane?
DrewD
I'm using the snippet you provided above, but for whatever reason the actual pane will not close
foreach (Pane pane in FrameworkApplication.Panes) {
   if (pane.ContentID == _viewPaneID) { //_viewPanelD is correct
foreach (var instanceID in myPaneInstanceIDs) { //close each of "your" panes.
   ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Closed pane " + instanceID);   //my addition, shows me that a pane is found
UmaHarano
Hi Drew
Just a couple of things that could be checked -
1.  The _viewPaneID property holds the ID from the DAML for your pane, correct?  It should be "ClosePane_Pane1" from the example snippet from config.daml below.
 <panes>
        <pane id="ClosePane_Pane1" caption="Pane 1" className="Pane1ViewModel" smallImage="Images\GenericButtonGreen16.png" defaultTab="esri_mapping_homeTab" defaultTool="esri_mapping_navigateTool">
          <content className="Pane1View" />
        </pane>
      </panes>
2.  While debugging your add-in when you place a breakpoint on this line below does it get hit? How many panes were open with that the _viewPaneID?  When a wrong InstanceID is passed to ClosePane method, I do see that nothing happens (seems to crash silently with no exceptions).
Thanks
Uma
DrewD
Thank you Uma, these are the results of the breakpoints below.
Here I'm using the variable PanelID to hold the _viewPaneID (which correctly matches my pane id in DAML).
Everything seems like it should be working, but the pane stays open
UmaHarano
Hi Drew
You are correct, all the breakpoints seem OK.  I am attaching a simple Add-in with a pane and a button. If you run this sample, you will see a Close Pane button. Please check if this sample works.
Thanks
Uma
