Obtain list of toolbox items in toolbox at runtime?
1191
01-27-2023 07:22 PM
JR99
Is it possible to open an existing toolbox (*.tbx) and read the tools into a collection?
Something along the lines of:
var toolboxPath = "C:\Data\ToolboxExample.tbx";
var toolbox = Toolbox.Open(toolboxPath);
ToolboxItemsCollection toolboxItems = toolBox.GetToolsList();
I'm wanting to write a WPF usercontrol that displays a list of all the geoprocessing tools in the toolbox, rather than needing to access them through the Catalog. I won't know at compile time which tools are in the toolbox so adding them as buttons in the DAML is not an option.
GKmieliauskas
Code for toolbox content below:
var gpItems = CoreModule.CurrentProject.Items.OfType<GeoprocessingProjectItem>();
      // go through all the available toolboxes
      foreach (var gpItem in gpItems)
          var itemsInsideToolBox = gpItem.GetItems();
          // then for each toolbox list the tools inside
          foreach (var toolItem in itemsInsideToolBox)
              string newTool = String.Join(";", new string[] { toolItem.Path, toolItem.Name });
              // do something with the newTool
              // for example, add to a list to track or use them later
If your toolbox is not added to project try to create it using ItemFactory:
var item = ItemFactory.Instance.Create(toolboxPath);
And add it to project.
More info here:
GeoprocessingProjectItem Class—ArcGIS Pro
Create Method (ItemFactory)—ArcGIS Pro
GKmieliauskas
More info here:
JR99
Thanks GintautasKmieliauskas! That's exactly what I was looking for.
