Map Control for User Selection in Dialog Box or WPF Window
2259
11-17-2023 08:46 AM
spaplanus2
I am evaluating moving an existing ArcMap project to ArcGIS Pro.   I need to see if there is an example of how to do this with the ArcGIS Pro SDK.   I have a wizard in ArcMap where one of the steps is a screen display with a map with a layer for the user to select features for the particular polygon layer.   I used the AxMapControl and AxToolbarControl to allow the user to do this selection.   If I move it over to ArcGIS Pro, I would need to have the same capabilities.    I was wondering if this is possible to do, or if I need to look at an additional developer api to make this work in the application.   Is there any examples or documentation on how to do this?
Steve
SusanPaplanus
Thank you for the suggested articles, they were helpful, but I am now stuck with how to enable the selection of an item on the map.  If I can figure out how to get something similar to the identify tool to work with the map control, then I think I have a complete path in order to get 90% of the functionality I need.   I appreciate the help you have given me on this.
Steve
GKmieliauskas
SusanPaplanus
OK, I looked at the code you suggested, which was helped a little bit further.  Now, I have the following code:
var uri = new Uri(out_feature_class);  // out_feature_class = 'C:\db\test.gdb\resultsInfo'
var featureLayerParams = new FeatureLayerCreationParams(uri);
FeatureLayer featureLayer = null;
Map currentMap = null;
try
await QueuedTask.Run(() =>
currentMap = MapFactory.Instance.CreateMap("tempMap", basemap: Basemap.None);
//TODO: use the map...
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.Message);
// now I assign the map I just created to the ViewContent of mapcontrol to display it
mapControl.ViewContent = MapControlContentFactory.Create(currentMap,initialExtent, MapViewingMode.Map);
featureLayer = LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerParams, currentMap);
});  // to add the layer to the created map that was added to the mapcontrol
The next step was to create a tool to allow for selecting one or more polygons from the results layer:
I took the code from the above example:
class SelectAndZoom : MapTool
/// <summary>
/// Constructor
/// </summary>
public SelectAndZoom()
IsSketchTool = true;
SketchType = SketchGeometryType.Rectangle; // rectangle sketch tool
SketchOutputMode = SketchOutputMode.Screen;
/// <summary>
/// On sketch completion select the intersecting features and zoom
/// </summary>
/// <param name="geometry"></param>
/// <returns></returns>
protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
return QueuedTask.Run(() =>
//select features that intersect the sketch geometry
var selection = MapView.Active.SelectFeatures(geometry, SelectionCombinationMethod.New);
//zoom to selection
return MapView.Active.ZoomToAsync(selection, TimeSpan.FromSeconds(1.5), true);
However, the OnSketchCompleteAsync never executes, even if I just try to change this to be just a single point select by changing SketchType to Point and CompleteSketchOnMouseUp= true. I believe the problem is that it does not capture the map control's map view (which is defined in its own dialog box).  It appears that I need to have it attach to the mapcontrol's map or mapview, but I do see how to change it from MapView.Active to the mapControl.GetMap() or mapControl.GetMapView() or even to mapControl.GetMapView().ToMapView().
I am stuck at this juncture, since all this does, including setting ActivateSelectAsync(true) in the constructor of the tool and cause the mapcontrol to pan and zoom.
GKmieliauskas
Take a look at Magnifier_MapTool how to bind your tool to mapcontrol
