List of invalid Field Name in Feature Class
971
11-12-2024 11:21 PM
JR99
Using the .NET SDK, I have found GeodatabaseHelperFunctions.BuildSchema() changes invalid field names however there no function to know which field names have been changed.
When I import a table from within ArcGIS Pro using Display XY Data, I can see that it is changing "Group" to "Group_". This is using the default file geodatabase that is created in the project.
So, clearly there are two elements which contribute towards a valid Field Name, 1. valid characters and 2. valid names, or rather NOT invalid names.
I've found documentation which lists valid/invalid characters but I can't really find the same for words beyond a generic, some words may not be valid.
This issue is causing me a problem when trying to map a DataTable column to the Geodatabase column. i.e. getting an invalid index exception.
For python, there's a ArcPy function ValidateFieldName_management however, .NET SDK does not have an equivilent.
I'm happy to write my own code however, I obviously don't know which names wouild be invalid.
Is there somewhere I can obtain the list of invalid Field Names?
KenBuja
MVP Esteemed Contributor
This post has several more lists of possible reserved words
JR99
I have managed to find out that SQL reserved words are not valid, however I don't know if this list is exhautive?
ADD
ALTER
AND
AS
BETWEEN
BY
CASE
CHECK
COLUMN
CREATE
DELETE
DROP
EXISTS
FROM
GROUP
HAVING
IN
INSERT
INTO
IS
JOIN
LIKE
NOT
NULL
OR
ORDER
SELECT
TABLE
UPDATE
VALUES
WHERE
KenBuja
JR99
Thank you!
Full list for the Esri geodatabase here: FAQ: What Are the Reserved Words for Esri's File Geodatabase?
• ADD
• ALTER
• AND
• BETWEEN
• BY
• COLUMN
• CREATE
• DELETE
• DROP
• EXISTS
• FOR
• FROM
• GROUP
• IN
• INSERT
• INTO
• IS
• LIKE
• NOT
• NULL
• OR
• ORDER
• SELECT
• SET
• TABLE
• UPDATE
• VALUES
• WHERE
