Issue in running MapTool code in different systems.
1115
06-25-2021 08:53 AM
TapasChakrabarty
I have a code that is calling MapTool through ICommand.Execute() and on mouse down, I am collecting the data. Everything is working fine on my system. But when I give the same solution to my teammate on his system ICommand is executing but the MapTool class is not getting called. Is there any setting on the ArcGIS Pro application to make it work? There is no change in code or version of code and API.
We are using ArcGIS Pro SDK 2.8 and VS2019.
Wolf
by Esri Regular Contributor
Can you provide the code snippet that doesn't work?
