Is it possible to hide or disable the "copy selected rows to the clipboard" button, located in the attribute table?
1179
08-18-2023 08:33 AM
Jose_AlfredoAlarcon
Is it possible to hide or disable the "copy selected rows to the clipboard" button, located in the attribute table? (the id of the button is "esri_editing_table_tableCopySelectedRowsButton").
I have tried to disable it with the OnCanExecuteCommand method but returning false does not do it:
protected override bool OnCanExecuteCommand(string cmdID, string moduleID)
            if (cmdID=="esri_editing_table_tableCopySelectedRowsButton")
                return false;
            return base.OnCanExecuteCommand(cmdID, moduleID);
I have also tried to hide it with the OnUpdateDatabase method, but removing it does not remove it either:
        protected override void OnUpdateDatabase(XDocument database)
            var nsp = database.Root.Name.Namespace;
            var btnElements = from seg in database.Root.Descendants(nsp + "button") select seg;
            var elements = new HashSet<XElement>();
            foreach (var btnElement in btnElements)
                if (btnElement.Attribute("id") != null)
                    var id = btnElement.Attribute("id").Value;
                    if(id == "esri_editing_table_tableCopySelectedRowsButton")
                        elements.Add(btnElement);
            foreach (var element in elements)
                element.Remove();
ArcGIS Pro 3.1
Thank you
CharlesMacleod
i think that button is part of the built-in menu for the table view control. The daml button is just there for shortcut keys. It's not actually on any menus - at least as near as i can tell. The only entries I found for that id were in Editing.daml....note that there is no refID for that button in any menus/groups etc. - just the shortcut.
<shortcut refID="esri_editing_table_tableCopySelectedRowsButton" key="C" flags="Ctrl+Shift" onKeyUp="false"/>
<button id="esri_editing_table_tableCopySelectedRowsButton" caption="Copy" extendedCaption="" className="esri_editing_EditingModule:TableManager.CopySelectedRows" smallImage="CopySelectedRows16" largeImage="CopySelectedRows32"
                loadOnClick="false">
          <tooltip heading="Copy Selection">
            Copy selected rows to the clipboard.<disabledText></disabledText>
          </tooltip>
        </button>
