Intersect but don't just share a boundary
2244
7
07-28-2023 11:57 AM
Cheetah24
Using the ArcGIS Pro SDK, how can I return a list of polygon features that intersect a feature in another layer but exclude those that just share a boundary. In addition, I would need to return any polygon that is spatially equivalent to the intersecting feature. I don't not want to change the selection set on the map, I just need a list. Thanks
Aashis
by Esri Contributor
Have you looked into the options from  SpatialRelationship property of SpatialQueryFilter?
If the available preset options are insufficient, you should create a Relate string following Dimensionally Extended Nine-Intersection Model (DE 9IM) and pass it to the SpatialQueryFilter as in the snippet.
Cheetah24
Thank you for the response.  We are working at 3.04 until some bug fixes are released. This approach appears for 3.1 and above. Is there alternative for 3.0?
CharlesMacleod
it works in 3.0 (and 2.x as well for that matter)
Cheetah24
Any idea why I can't access Relation or SpatialRelationshipDescription ?
CharlesMacleod
fully qualify SpatialRelationship. Something in your code is conflicting with it
Cheetah24
I have attempted that. I don't see it listed in the 3.0 documentation either.
https://pro.arcgis.com/en/pro-app/3.0/sdk/api-reference/topic6828.html
CharlesMacleod
yes, i agree, looks like that particular enum value is not part of the GDB at 3.0.
