ILayerExtensions in ArcGIS Pro SDK
4223
03-11-2016 03:01 AM
MickeyO_Neil
Hello,
I'm writing an Extension for ArcGIS Pro. This Extension is creating special Layers which has to be recognised after saving and loading an aprx-File.
In ArcObjects I used the ILayerExtensions and stored a unique String in the Layer to identify it after loading a MXD.
What equivalent do you recommend for ArcGIS Pro? Is there a new/better way to store Data in a Layer or APRX-File?
Thank you for your Help.
Cheers
Mickey
MickeyO_Neil
I have found a workaround:
That's how you store data in the Project-Settings:
https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-Custom-settings#step-6-implement-the-module-cla...
This way you even can store JSON or XML strings in the APRX-File.
Furthermore you can use the URI Property of a layer as a unique identifier:
https://pro.arcgis.com/en/pro-app/sdk/api-reference/index.html#topic11759.html
MickeyO_Neil
Who should I contact for help? I really need a solution to this problem.
JeremyWright
MickeyO_Neil
