I get error on a SearchTextBox on XAML saying SuggestionSource property not found
1426
07-06-2022 08:44 AM
Amadeus111
I used to run this w/o a problem but now saying there is no SuggestionSource property. I am migrating my AddIn to 3.0/.Net6. I check the documentation. I didn't find any info that says SuggestionSource replaced/removed.
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic15062.html
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic15120.htmlhttps://pro.arcgis.com/en/...
Does anyone know what might be the issue?
<controls:SearchTextBox x:Name="SearchLayersBox" Height="23" Width="212" Margin="5,5,5,10" Grid.Row="0" Grid.Column="0"
                                                VerticalAlignment="Top" InfoText="Search layers here"
                                                SearchMode="Auto" ShowHistory="True" SuggestionListMax="15"
                                                ToolTip = "{Binding SearchLayersBoxToolTip, UpdateSourceTrigger=PropertyChanged}"
                                                Text="{Binding SearchLayersBoxText, UpdateSourceTrigger=PropertyChanged}"
                                                SuggestionSource="{Binding SearchLayersBoxSuggestionSource, UpdateSourceTrigger=PropertyChanged}"
Wolf
by Esri Regular Contributor
Using your XAML I made a 2.9 sample and then migrated the sample using the Pro Migration tool vsix: ProConcepts 3.0 Migration Guide · ArcGIS/arcgis-pro-sdk Wiki (github.com)
I attached my sample project for your reference.  The SuggestionSource property still exists, and my 3.0 add-in project compiled without error after the migration.   You can't find the SuggestionSource  property in the API reference guide because it is inherited from the ArcGIS.Desktop.Internal.Framework.Controls.SearchTextBox control and our online API reference guide always excluded such inherited "Internal" properties hence the property was not documented in the 2.x API reference guide.   Such properties can be used in add-ins but are not supported by the Pro API regarding the API's 'forwards compatible across minor releases of Pro' support.
My sample code implements an initial Suggestion list:
and updates that list during runtime by clicking the button that adds feature layer names to the suggestion list.
Wolf
Amadeus111
@Wolf Thanks for the reply. I will check out and let you know. I use SearchBox heavily in my AddIns.  I gotta figure this out
Amadeus111
@Wolf I just realized I didn't do Pro Migrate Solution. After the migration 2->3 it works fine. I am sorry! I should have paid more attention. Knowing there is no problem pushed me find my own mistake. Thank you for your support, I appreciate that.
Wolf
Ok, that explains it.   I guess the Migation guide ( ProConcepts-3.0-Migration-Guide  ) in the ArcGIS Pro SDK wiki could be a bit more frontline and center.
